owenexile
Joined: 05 Jun 2009 Posts: 333 Location: Australia , Bunbury
Posted: Thu Oct 28, 2010 10:42 am Post subject: Taking out Ignition? |
Is it hard to pull the ignition? I need to connect a immobiliser wire up again , and i cant reach it from underneath the dash because the wire is about 3cm long. Any precautions i need to take here?
Thanks _________________ 924 1982 N/A
For some reason theres always a earth problem somewhere with this car... |
leadfoot
Posted: Thu Oct 28, 2010 8:07 pm Post subject: |
Center the steering wheel before you take it off.
don't crossthread the housing bolts when you screw back in the switchgear.
Only if you need to take out the barrell are there tricky bits, all pretty straight forward stuff.
you'll need a 24mm socket and a short extention bar for your ratchet
carbon fiber GT mish mash
Posted: Fri Oct 29, 2010 4:00 am Post subject: |
Why go to all that trouble?
Grab the wires running to the ignition switch up behind the fuse/relay pane, and cut in there. |
owenexile
Posted: Fri Oct 29, 2010 5:26 am Post subject: |
The wire im looking for is a wire witch is all by itself and comes straight out of the ignition and doenst go anywhere and one wire of the immobiliser needs to connect up to it. _________________ 924 1982 N/A
camfella
Joined: 20 Jul 2010 Posts: 42 Location: Ottawa - Canada
owenexile
Posted: Sat Oct 30, 2010 3:55 am Post subject: |
Thanks Mate , that really helped. _________________ 924 1982 N/A
camfella
Posted: Sat Oct 30, 2010 8:54 am Post subject: |
| owenexile wrote: | | Thanks Mate , that really helped. |
I only knew about it cause someone else on the board helped me out!
Love this message board for getting help, its great.
 _________________ 1987 924s |
RC
Posted: Mon Nov 01, 2010 2:54 am Post subject: |
| gohim wrote: | Why go to all that trouble?
Besides that, even a remotely intelligent car thief will look under/ rip off wires at the ignition switch. Doesn`t take much brains to jump a relay or cut & twist 2 wires.
Another relay at the fuse/ relay panel is more inconspicuous. Rewire or protect the fuel pump circuit as well or even instead. So simple to jump the battery to coil +, why bother with the key.
BTW, no I`m not a car thief.  _________________ World`s quickest 924 2L slushbox
