Dutch924-racer
Posted: Sat Nov 13, 2010 3:46 am Post subject: How do you fit a carrera gt front bumper ? |
I am converting my 931 to 937 body.
I assume you have to make brackets ? _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
joecitizennn
Posted: Sat Nov 13, 2010 9:22 am Post subject: |
| depends on who made it and how it was made. Some companies provide better mounting than others. For instance, GT racing provides next to no mounting provision, instructions, or helpful advice by phone. "We dont advise on mounting our products sir, we assume a professional shop will handle the installation." |
Nein37
Joined: 29 Dec 2009 Posts: 513 Location: New London, CT
Posted: Sat Nov 13, 2010 2:22 pm Post subject: |
The AIR GTS front bumper is fairly easy to mount, they leave a reinforced mounting surface over each wing just like the 944 front valance. _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
Dutch924-racer
Posted: Sun Nov 14, 2010 11:00 pm Post subject: |
I thing I wil drill two holes and make new brackets.
I need two rubber pads. Can I use them from a 944 (eu) ? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Dutch924-racer
Posted: Thu Nov 18, 2010 2:02 am Post subject: |
Can anybody post some pictures of the inside of the GT bumper en of the brackets ??? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
v8carreragts
Posted: Thu Nov 18, 2010 2:58 am Post subject: |
| I have the AIR for mine. I have bolts on the outside edges at the fenders, (like the stock 944) I made 2 brackets to mount at the original bumper locations and plan to make attaching brackets on the inside of the bumper to connect to. I also have removed the front body crossmenber and replaced it with a 12 ga. C shaped chanel. I have it made so the top sandwiches the top bumper edge between it and the front nose panel. I am also planning on adding a steel stiffener to the inside bottom edge. |
