pilot bearing removal
Scorpio
PostPosted: Tue Dec 21, 2010 8:37 am    Post subject: pilot bearing removal Reply with quote
Absolutely the most anoying thing ever
Notice 20kg weight on slide hammer---bent nail-- bent slide hammer puller handle
looks worse then it is but i dont think i ruined the interference fit of the old hole
ended up just grinding it out--4-5 hrs of BS
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
Rich H
PostPosted: Tue Dec 21, 2010 10:10 pm    Post subject: Reply with quote
Grind - it's the only way.
peterld
PostPosted: Tue Dec 21, 2010 10:48 pm    Post subject: Reply with quote
Scorp.......love those Chinese safety boots! Pretty shade of white....must be food service grade.
80/81 932/8 ROW
PostPosted: Wed Dec 22, 2010 5:11 am    Post subject: Reply with quote
Huh, mine came out without grinding:
http://www.924board.org/viewtopic.php?t=32178 (see bottom of the thread)
You just need the proper tools (A long bolt/stud, a couple of nuts, a large washer and a plumbing adapter), a little heat to expand the outer metal and a cooling spray to contract the inner portion.
Finally, patience is the key. Going slow and making sure you don't strip the threads. Use a standard ratchet and gently apply more and more pressure until it begins to move.
poorsha924
PostPosted: Wed Dec 22, 2010 6:29 am    Post subject: pilot bearing removal Reply with quote
Its a little late now but next time notice there is a threaded hole in the pilot beraing I believe it is 10MM, thread a long bolt into it & tighten the bolt it will bottom out on the end of the crank & pushes the pilot bearing out much easier
poorsha924
79 924S snailshell
audi big bore t-body
16" turbo wheels
Rich H
PostPosted: Wed Dec 22, 2010 6:52 am    Post subject: Reply with quote
Or it'll just rip the threads out of the pilot bearing housing.... like mine did.
Scorpio
PostPosted: Wed Dec 22, 2010 11:56 am    Post subject: Reply with quote
as did mine.... And the majority of people who have tried 'porsches' method
Heating may have worked when the crank was off but I unfort didn't do it then and if I did it now I would have damaged the rubbery seal
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
leadfoot
PostPosted: Wed Dec 22, 2010 11:17 pm    Post subject: Reply with quote
Is the turbo pilot bearing the one that sits in the flywheel or is there another that sits inside the crank too?
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Rich H
PostPosted: Wed Dec 22, 2010 11:33 pm    Post subject: Reply with quote
Turbo sits in the fly only, N/A bearing case sits in the crank only.
PostPosted: Thu Dec 23, 2010 6:08 am    Post subject: Reply with quote
The heat won't hurt the seal as long as you only heat the center of the crankshaft. You don't need to make it cherry red, just warm enough to expand a bit, then hit the center with a cool spray to cause it to contract quickly to reduce the friction and any corrosion that may contribute to holding it in place. Do it a few times quickly, back to back and it should make it a little easier to remove without destroying it.
A little PB Blaster (not WD-40, which is a lubricant, not a product for breaking up rust) or similar corrosion reducing liquid. Diesel fuel and ATF supposedly work better than anything on the market for breaking rusty parts free.
Also, you don't turn the bolt to push the pilot bearing housing out using the threads, you use the threads to hold the bolt while you use the nut against the washer to pull the piece out.
Slam
PostPosted: Thu Jan 20, 2011 8:03 am    Post subject: Reply with quote
Well, Scorp, you didn't read the How-To section like a good little mechanic. Stefan posted a great procedure after I'd put up some stuff.
Still, you got it out and that's what matters.
Julian
PostPosted: Wed Jan 26, 2011 1:29 am    Post subject: Pilot Reply with quote
Heat around the outside of the hole can help. There is an old trick that works sometime. Fill the hole with the most thick bearing grease you can find, take the input shaft from an old tranny or a solid bar the same size as the input shaft.
Drive the input shaft or the bar into the pilot hole with a large hammer. The grease will be driven under the backside of the bearing and hydrolyticly move the bearing outward. Will not work ALL the time, but worth a try before frustration takes hold.
Scorpio
PostPosted: Wed Jan 26, 2011 1:44 am    Post subject: Re: Pilot Reply with quote
Tried it-- no luck, our pilot bearings don't have a decent sized inner face surface area like a normal bearing
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
PostPosted: Fri Mar 18, 2011 6:55 am    Post subject: Reply with quote
... Its not here.
sbarc
PostPosted: Sat Mar 19, 2011 1:32 pm    Post subject: Reply with quote
Wouldn't a pilot bearing puller be easier?
Here's one for $16.00
http://www.tooltopia.com/mountain-9001.aspx?utm_source=nextag&utm_medium=cse&utm_term=MTN9001&utm_campaign=nextag_r1
The one I use is more expensive.....it's a Toyota Special Service Tool (SST).....I bought it long ago and I've done dozens of clutches with it. The pilot bearing just slides out as easy as can be.
http://www.costplustools.com/OTC-Toyota-09303-35011-PILOT-BEARING-PULLER-Supra_p_8636.html
1981 931 (Canadian car)
1981 931 (US car)
1990 928GT (ROW car)
1991 Toyota MR2
1989 Toyota MR2 Super Charged
1985 Toyota Supra
1973 Triumph GT6
1971 Opel GT
