joecitizennn
Posted: Tue Jan 18, 2011 11:41 am Post subject: |
Could you tell us more about the AIR rear flares? When I did my cgt project I used gt racing flares and found much to want. What kind of flare-to-body mounting provision does the AIR flare have? Does it have pre installed studs? Does it have a mounting lip along the inside of the top edge?
The reason I ask, is my gt racing flares required some glass work before they were even mountable. All they consisted of was the basic outer shape. That's all. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
mvallee
Posted: Tue Jan 18, 2011 12:09 pm Post subject: |
The AIR flares have a flange, thats it, no hardware to attach to the body.
I wasnt happy with the fit, I cut off the flanges and made my own. Used these http://www.mcmaster.com/#threaded-rods-and-studs/=amxac2 inside the new flange.
Added an inner wheel well with another flange around the back edge of the wheel opening like the original. _________________ Auburn, NH
1987 Porsche 924CGT in progress
1974 Porsche 914/6 next project
1965 Alfa Romeo Spider Veloce restored
1953 Alfa Romeo 1900C Ghia Bodied Coupe project |
joecitizennn
Posted: Tue Jan 18, 2011 12:25 pm Post subject: |
I have always thought that the 951 is the ultimate evolution of the carerra gt, so I will be interested to see a carerra gt with a 951 powerplant. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
stv951
Posted: Sun Jan 23, 2011 6:50 am Post subject: |
| joecitizennn wrote: | | I have always thought that the 951 is the ultimate evolution of the carerra gt, so I will be interested to see a carerra gt with a 951 powerplant. |
I agree 100%
I am also starting the same project based on a 924S
Will use 951 power |
Posted: Sun Jan 23, 2011 6:32 pm Post subject: |
I'd have thought it is easier starting with a 951 as a base and grafting on 924 rear wings then the CGT flares!
Even if you wanted an early dash it may be easier to swap that over with the necessary tweaking required.
You will also need to swap out the nose section to enable a 951 IC as the 951 is different to a 924. Plus suspension, brakes, rear frame, gearbox, torque tube etc. etc. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
mvallee
Posted: Mon Jan 24, 2011 1:23 am Post subject: |
It would be easier, there was someone on Rennlist that did that when his wife wrecked his car. I thought of doing that but didnt have a title for the parts car.
The front end conversion wasnt that bad, but without a parts car I wouldnt even try.
The rear frame is identical once you cut the 924 crossmember out. Correct holes for the bolt in crossmember are already there.
My 924S already had 951 brakes and suspension so I only needed the transaxle and engine. After selling the original parts the price of the swap wasnt bad. _________________ Auburn, NH
Posted: Wed May 09, 2012 4:48 am Post subject: |
Hey, is this car done! We need more pics! Are you still alive?  _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
mvallee
Posted: Wed May 09, 2012 6:13 am Post subject: |
I'm still here. Nope, not even close, it's just about ready for paint. I changed the front bumper design 4 times now, still not happy with it.
I'll try to get some pics this weekend. _________________ Auburn, NH
Posted: Wed May 09, 2012 7:35 am Post subject: |
Cool, I'm tackling the rear AIR fender flares, and want to make sure I don't eff it up. Have been researching placement, etc. Yours is such a clean look, I"m about 75% into that, track car, ugly is ok. _________________ '83 944 Track car.
