924turborox
Posted: Sun Jan 23, 2011 10:55 am Post subject: myth busters |
I've heard about the hype synthetic engine oils are getting.
Any truth about them?
Also, what about Royal Purple? _________________ 1980 porsche 924 turbo 5speed getrag gearbox |
joecitizennn
Posted: Sun Jan 23, 2011 11:04 pm Post subject: |
if you have not heard anything about the deletion of ZDDP from standard engine oil in the last several years then you have some reading to do. Synthetic oil is a must for older cars unless you are running a diesel or race oil with adequate quantities of ZDDP. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
924turborox
Posted: Mon Jan 24, 2011 2:35 am Post subject: |
I had read and heard about the reduction/deletion (I'm not exactly sure which) of ZDDP which is why I was a bit worried about it.
Any particular synthetic that you'd recommend? as opposed to the Valvoline VR1 20w50 I'm using at the moment anyway. _________________ 1980 porsche 924 turbo 5speed getrag gearbox |
CorsePerVita
Posted: Mon Jan 24, 2011 4:32 am Post subject: |
I prefer to stick with brad penn.
but oil is going to vary a lot with opinions. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Rattlinbone
Posted: Mon Jan 24, 2011 4:57 am Post subject: |
I had the same question a while back. After a little time at the library reading consumer reports, scouring message boards and gathering opinions, the answer I came up with is that Valvoline VR-1 20w-50 or Kendall GT-1 20w-50 is the way to go. But apparently it's a matter of opinion. _________________ Fred- 1979 924 |
joecitizennn
Posted: Mon Jan 24, 2011 6:45 am Post subject: |
Valvoline vr1 is fine, but not a good oil to keep in your engine for a long period of time. Synthetic is a better daily driving oil. The argument over what kind could go on for 1000 pages. I say you can't go wrong with Mobil 1. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
Julian
Posted: Tue Jan 25, 2011 2:20 am Post subject: Oil |
I switch everything I own to synthetic after break-in. Lawn mover, to work truck. My work truck has 180,000 miles on it. Last year I replaced the tranny so while I was that close I replaced the oil pump and rear seal.
The number 5 main bearings show no signs of wear still grey as they were when new. The truck still has the oil pressure that it did when new also.
Cost a little more, but I still change the oil between 2,500 and 3,000 miles.
When knurling guides the resizer at times will stop in the valve guide. When that happens I use synthetic oil to get the resizer to clear the valve guide. That's how slick that stuff is.
Draw back. If you have a gasket that might leak with regular oil, it will for sure with synthetic. It smells worse also, when it burns on an exhaust system. |
Posted: Tue Jan 25, 2011 2:36 am Post subject: |
Hype? you write about synthetic oil like it was something new and unknown. Its been standard in the industri for years. Why not take advantage of 100 years of development I wont put anyhing other than a resonable specd synthetic in my cars, race car or daily driver dont matter (just different viscosity grades).. _________________ 1980 924 Turbo
Posted: Tue Jan 25, 2011 3:40 am Post subject: |
brad penn
It is not just synth/non-synth, it has to do with the flat-tappet overhead cam motors and zddp-deficient oils causing premature wear to followers and cams.....
but you pick what works for you |
924turborox
Posted: Fri Jan 28, 2011 10:14 am Post subject: |
Thanks 924ers
I meant hype as in the kind I've been getting from people trying to sell me stuff. _________________ 1980 porsche 924 turbo 5speed getrag gearbox |
