the_mad_electrician
Posted: Mon Jan 24, 2011 7:51 am Post subject: Shreaded Timing belt! |
driving along the interstate engine starts running wierd then not at all. Pop the hood and all the teeth on the timing belt are Gone! Damn I just replaced that thing 6 months ago. Got a new one but I had to leave my car on the side of the road because I have to go get the kids.  _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
!tom
Posted: Mon Jan 24, 2011 8:16 am Post subject: |
Tension must have been incorrect. _________________ 78 924 NA
5-lug |
the_mad_electrician
Posted: Mon Jan 24, 2011 8:43 am Post subject: |
| !tom wrote: | | Tension must have been incorrect. |
Too tight or not tight enough? The haynes manual said to tighten it until you could twist it 90 degrees.... _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Martijnus
Posted: Mon Jan 24, 2011 10:03 am Post subject: |
| the_mad_electrician wrote: | | !tom wrote: | | Tension must have been incorrect. |
Too tight or not tight enough? The haynes manual said to tighten it until you could twist it 90 degrees.... |
so the tough guys have a more manly amount of tension on their belts.
It's a good indication though... but I thought it was too tight and gave it a little bit less.
Haven't had any problems with that.
So I guess yours was too tight. Too little tension would cause it to slip once, I guess... while too much tension wears it out really fast. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Mon Jan 24, 2011 10:04 am Post subject: |
Tensioner fail. _________________ Toofah King Bad
CorsePerVita
Posted: Mon Jan 24, 2011 11:05 am Post subject: |
Agreed with rasta. Something bound it up or it was way too loose and started skipping teeth. Look on the bright side, it's not a 944, so line up the marks and put a new belt on, good to go. Well... and replace the tensioner if that's the issue. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
the_mad_electrician
Posted: Mon Jan 24, 2011 11:39 am Post subject: |
Replaced belt car running fine but I think I will order a tensioner soon as I can! _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
jacobscott209
Posted: Mon Jan 24, 2011 12:43 pm Post subject: |
is the 2.0 an interference engine? _________________ 77924 |
the_mad_electrician
Posted: Mon Jan 24, 2011 12:52 pm Post subject: |
Not the N/A, I think the turbo is though _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
joecitizennn
Posted: Mon Jan 24, 2011 2:38 pm Post subject: |
A 944, and you'd be dead. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
CorsePerVita
Posted: Mon Jan 24, 2011 5:11 pm Post subject: |
| jacobscott209 wrote: | | is the 2.0 an interference engine? |
nope, isn't it nice? 2.0L N/A is a non-interference. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
Posted: Tue Jan 25, 2011 1:36 am Post subject: |
| the_mad_electrician wrote: | | The haynes manual said to tighten it until you could twist it 90 degrees.... |
BTW, this can be tricky if you have any hand strength whatsoever. I can twist mine 90° with the tensioner adjusted to max, which results in the belt being MUCH too tight. The key is not to twist it as far as you can, rather just to twist it until you can feel the belt begin to stretch. Takes some concentration, but you'll get a feel for the "stretch point." _________________ Toofah King Bad
Slam
Posted: Tue Jan 25, 2011 3:14 am Post subject: |
I agree with Rasta. I use twist method, which results in a belt that's WAY too tight. Then I back it off until it stops whining. Replace the tensioner every couple of years. They're cheap. _________________ '88 944 Auto - may or may not resurrect |
Posted: Tue Jan 25, 2011 8:08 am Post subject: |
belts deteriorate over time.
I bought a belt once that lasted a week. Must have been real old stock.
The next one is still on there - bought elsewhere. _________________ Porsche 924 1984 (UK import) NA
Posted: Tue Jan 25, 2011 12:45 pm Post subject: |
Only buy Gates belts.
Contitech belts are junk. _________________ 3 928s, |
