Crappy workmanship or what...
Brian Bailey
PostPosted: Tue Jan 25, 2011 4:16 pm    Post subject: Crappy workmanship or what... Reply with quote
I recently swapped out my starter ('78 924) with a rebuilt Bosch. Hated it. Enjoyed several drives, then she wouldn't start. No solenoid action, lights, etc. Tried boosting the battery - cold here in Alberta - big draw from the donor battery - some melting of the cables. Being an electroniphobe, should I presume a ground fault, faulty starter, crappy workmanship...
Thanks, B
staticsan
PostPosted: Tue Jan 25, 2011 8:13 pm    Post subject: Reply with quote
Dud or just wired wrong?
The '924 starter has a relay in it to help deliver the current. My understanding is that this is rather unusual; it took my Dad and I a long time to figure this out from the Haynes diagram, after wondering quite what that extra relay was lurking in my engine bay!
Wade.
Slam
PostPosted: Wed Jan 26, 2011 2:27 am    Post subject: Reply with quote
Did you refurb the wiring harness from the batt to the starter and alternator? That can cure many problems. There shouldn't be any melting of wires, even boosting at very cold temps. Improper grounding is a constant issue as well. Maybe pull the starter and have it tested?
!tom
PostPosted: Wed Jan 26, 2011 2:43 am    Post subject: Reply with quote
Seized engine?
In the super cold weather you're having, what engine oil are you using?
78 924 NA
5-lug
jacobscott209
PostPosted: Wed Jan 26, 2011 3:56 am    Post subject: Reply with quote
I have a similar problem. If I wiggle and pull on the wires it will usually fire. Haven't had a chance to get around to it yet. I'm thinking something happened to the wires from being next to the exhaust because the connections are solid and clean.
Brian Bailey
PostPosted: Sat Jan 29, 2011 12:00 pm    Post subject: Reply with quote
So… I changed the starter (rebuilt Bosch), which had spinoff pleasures like removing exhaust and sheild components, but thought I’d done a decent job. The car started several times, got me to work but failed to get me home. No electrics were functioning. Dead battery? So I tried boosting, resulting in over-heating booster cables.
After pushing it into a shop, I have concluded the following:
There is continuity (zero resistance) between the battery cables after removing the battery.
After splitting the two red leads from the main positive cable, red leads no continuity, main cable, continuity.
Visual inspection shows no sign of worn shielding or arcing on the main lead. Terminal connections at the starter appear correct.
So… Is it possible the starter is defective in a way that current will arc through it when it is not activated?
Is there anything to do besides repeat the starter removal and have it tested?
I’ve probably just answered my own question, but would appreciate some outside inspiration!
Thanks.
daniel
PostPosted: Sat Jan 29, 2011 1:42 pm    Post subject: Reply with quote
In short, yes the starter can short. But I would first pull the positive lead from the solenoid and see if you still have a short to earth.
Good luck
1989 944 Cabriolet
!tom
PostPosted: Sat Jan 29, 2011 4:17 pm    Post subject: Reply with quote
You should have continuity between the battery cables with the battery removed, or else there would be nowhere for the juice to go when the battery is connected.
You'd be getting continuity through the clock in your dash and your radio keepalive, among other circuits.
Your troubleshooting is going to have to be far more involved.
Check for a short from the main wire going to your starter to ground somewhere. It's entirely possible the insulation is damaged and you have a direct short here or associated wiring.
78 924 NA
5-lug
Brian Bailey
PostPosted: Mon Jan 31, 2011 2:34 am    Post subject: Reply with quote
Thanks for your assistance, folks!
jeanette
PostPosted: Fri Feb 04, 2011 4:22 am    Post subject: non starting,no dash lights no nothing, then..... fine Reply with quote
oh gosh.....
Just had two similar experiences with "Janis"<---( AKA '78 924 brat)
She ran fine on the freeway, twisties, over some lumpy road...shut her off to deliver stuff to my Mom, (about 20 minutes).... then no lights,no cranking, no starting..... no nothing.
Turned the key over tried again...nothing.
Popped the hood, and did the "seriously stupid looking" wigglethewires at the negative battery post....and she started perfectly.
(Don't think this problem is due to the ignition switch.)
Ran great all the way home....
Three days later pulled her out of the garage... and again no starting.
Same "stupid looking" wire fiddling got her to start and run fine.
Not cold or damp here on either day.
Seems if there is a loose wire or bad ground, there should be at least a few hiccups or rough running.....?
I give, as I can't seem to duplicate this on a whim, and I really am wondering if there isn't a wire touching with the hood down...?
Dirty negative battery post?
jeanette
"person who says it cannot be done should not interrupt person who is doing it"
Brian Bailey
PostPosted: Fri Feb 04, 2011 11:01 am    Post subject: Reply with quote
The final (hopefully) comment on this topic. I put the car on a hoist, (MUCH better than my car jacks and creeper!) removed ancillary parts and discovered what was suspected. The main cable at the starter terminal had found ground, which accounted for zero resistance through the battery cables. I loosened the cable, rotated it about 90 degrees, checked resistance, found a reasonable reading due to dash components, reinstalled exhaust etc, and presto! There was no rubber boot over the connector (maybe once was), but the title of my inquiry suits my job well: "Crappy workmanship or what". :oops:
Jeanette, disconnect the battery and connect an ohm meter across your battery cables. Zero resistance?
jeanette
PostPosted: Fri Feb 04, 2011 12:07 pm    Post subject: Reply with quote
Will have to get a meter.
Ran Janis hard with a zillion starts and stops today, and she was as (usually) always... perfect.
Still... knowing what a Drama Queen she can be... I had better head this off now.
Thanks!
jeanette
