RC
Posted: Mon Nov 29, 2010 4:33 pm Post subject: Any demand for another group buy on valvesprings? |
I keep getting inquiries about valve springs, even though the few spare sets I one had are long gone.
Post your interest here for stock replacement springs to suit both N/A and turbo. These come as as boxed set of both inner and outer springs. Same as the last group buy. Budget for at least $100 AUSTRALIAN DOLLARS, whatever that is in your local currency. PLUS shipping. Any final price TBA.
Also may look into a bigger, longer, harder version, if there is the interest. Actually have a sample here of the extra performance version and a handful of various retainers as well. Higher revving, higher lift, higher boost. Goal is to replace the stock rotators with extra spring coils. _________________ World`s quickest 924 2L slushbox
engineer.white
Joined: 19 Aug 2008 Posts: 61 Location: New Bern, North Carolina
Posted: Mon Feb 07, 2011 2:41 am Post subject: |
I am in for a set, sure does look like response to this is pretty low, maybe it should be in the Wanted and For Sale section... I will be tearing into a cylinder head in a few months, would be nice to have new springs.
David _________________ 1981 924 turbo/931
1982 924 turbo/931
1986 911 turbo/930 |
Posted: Mon Feb 07, 2011 2:54 am Post subject: |
Very pleased with my set. Thanks again, RC. _________________ Toofah King Bad
tyfighter123
Posted: Mon Feb 07, 2011 5:25 am Post subject: |
What would shipping be to the USA? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 924S 1987 (parts car)(cut up and recycled)
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car) |
Posted: Mon Feb 07, 2011 5:54 am Post subject: |
i'm interested as i'm doing some head work on my turbo.
could you quantify the improvements over stock springs?
100 AU$ for a complete set?
thanks. _________________ Supercharger and EFI kits
gegge
Posted: Mon Feb 07, 2011 6:00 am Post subject: |
Still got the set from the last group-buy. My enginebuilder told me they were too short and needed spacer Could be the valveseats..?
Well, I am interested in a set for a high-lift cam. Coilbind is therefore very important. No need to make them harder since I intend to use lighter valves. _________________ Carl Fredrik Torkildsen
Posted: Mon Feb 07, 2011 6:13 am Post subject: |
| morghen wrote: | | could you quantify the improvements over stock springs? |
Your stock springs, if factory original, are worn out and likely allowing the valves to float. . .bad. This is a fairly low cost, and fairly mandatory item for refreshing a high mileage toofah head, IMO. _________________ Toofah King Bad
daniel
Posted: Mon Feb 07, 2011 5:10 pm Post subject: |
I would be interested in say 2x high performance set's
Cheers
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Mon Feb 07, 2011 5:42 pm Post subject: |
| Rasta Monsta wrote: | | morghen wrote: | | could you quantify the improvements over stock springs? |
Your stock springs, if factory original, are worn out and likely allowing the valves to float. . .bad. This is a fairly low cost, and fairly mandatory item for refreshing a high mileage toofah head, IMO. |
agreed, but i'm interested if i need to do any other work on the head because of these springs. i dont want to have to replace the valves or something just because of that. _________________ Supercharger and EFI kits
Posted: Tue Feb 08, 2011 1:14 am Post subject: |
RC can answer for sure, but I think these are direct stock replacements and don't require any mods to install. _________________ Toofah King Bad
Posted: Tue Feb 08, 2011 1:38 am Post subject: |
| Rasta Monsta wrote: | | RC can answer for sure, but I think these are direct stock replacements and don't require any mods to install. |
I've installed two sets, both for big valve heads, and had no issues. Should be direct fit replacement for OEM.
If anyone is interested, I can get complete sets of heavy duty springs (the same ones used in the EMW big valve setup) that are recommended for anything beyond a Stage II cam. The HD springs do require a special spring seat on the exhaust valve, which comes with the set. As far as I can tell, these are pretty much available on-demand, no minimum purchase or special ordering. _________________ erstwhile owner of just about every 924 variant ever made |
gegge
Posted: Thu Feb 10, 2011 2:17 am Post subject: |
Would be possible to make light (titanium) retainers for a valve with thinner stem? _________________ Carl Fredrik Torkildsen
Posted: Thu Feb 10, 2011 2:25 am Post subject: |
I'm sure it could be done, but I'm also fairly certain my supplier would want a valve sample in order to produce something like that... _________________ erstwhile owner of just about every 924 variant ever made |
