jbwheele
Joined: 09 Jun 2010 Posts: 72 Location: Invercargill New Zealand
Posted: Wed Mar 09, 2011 10:10 am Post subject: BP eat your heart out ! |
I just started the new engine for the first time.....purred like a kitten Then I decided to turn it off before it got any temp up. Didnt stop dont panic wiggle ingition key and pull it out.............. ok disconnect battery .......dont panic....... still going.........ah disconnect alternator ignition feed .....still running......start to panic disconnect feul pump leads at rear......still running, wait ! its a turbo......find turbo timer (aftermarket ) that I should have thought about first.........engine stops.....
Ok all good.......hey whats that oil under there? Take front pulley off, using 23mm socket and car jack as torque.........forgot front oil seal......... Moron! ........Get detergent and rags clean driveway.
Dickhead!
Install front seal.........dont panic.........think first..........check oil leaks after warm run. retighten as many bolts as possible after initial run.
BLEED Water /cooling system.! _________________ Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap |
El Chato
Posted: Wed Mar 09, 2011 10:40 am Post subject: |
wow,, talk about dieseling the engine. keep it up im rigth behind you on the rebuild engine start phase, I plan to run the engine on and engine test stand I'm building to sort out any anomalies, dont know if you can approach it that way at this point. _________________ 1979 924 N/A, Snail Shell
1980 924 N/A
1976 924 N/A
It may be that your whole purpose in life is simply to serve as a warning to others.
Today's weirdness is tomorrow's reason why. |
datatrain
Joined: 15 Sep 2007 Posts: 441 Location: Osoyoos, British Columbia
Posted: Wed Mar 09, 2011 12:56 pm Post subject: Curious |
Invercargill isn't or wasn't that the home of Bert Munro the guy with the
worlds fastest Indian ? _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR |
jbwheele
Posted: Wed Mar 09, 2011 6:00 pm Post subject: Yes |
And the worlds slowest 924, also Keith Richards and Mick Jagger, wrote paint it black about when they got Boo'd off stage by the locals for playing like S..t, Too stoned and Pissed. Aparently there is still a Red Door in the old hotel they stayed in .......Urban Myth ?
jbwheele
Posted: Wed Mar 09, 2011 6:01 pm Post subject: Oh yes |
Also they called it the Ass hole of they earth.  _________________ Joe
Posted: Thu Mar 10, 2011 3:00 am Post subject: |
Hmmm, i need to see this door...a great piece of american history!  _________________ NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1967 |
