gla924sem
Joined: 08 Nov 2002 Posts: 405 Location: Taylor, Michigan
Posted: Tue Mar 15, 2011 10:03 pm Post subject: 1982 924NA Main & Con Rod Clearence |
Going to start putting the short block back together after getting it back from the "REBUILDER".
Want to check his work so there's no surprises......I hope......so I am going to "Plastigage" the mains and con rod bearing clearences.
Any one have what the spec should be for stock bearings? |
Posted: Tue Mar 15, 2011 10:53 pm Post subject: |
Offhand, I seem to recall that the clearance for "new" bearings is 0.0008-0.001", and the wear limit is 0.003-0.004".
OK, from the manual...
Con rod radial clearance, .02-.07mm new, wear limit .1mm (.0008-.003" new, .004" wear limit)
Main crank bearing radial clearance, .02-.08mm new, wear limit 0.16mm (0.006" wear limit). _________________ Vaughan Scott
gla924sem
Posted: Tue Mar 15, 2011 11:13 pm Post subject: 924 |
Thanks......knew either you or Dan would respond.
Am hoping those guys in Warren did me no wrong. |
Posted: Wed Mar 16, 2011 12:16 am Post subject: |
Fingers crossed for you, Gary. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Mar 16, 2011 1:18 am Post subject: |
As confused as they might get, I would be very surprised.
Feel free to post back w/ your measurements, for feedback... _________________ Vaughan Scott
gla924sem
Posted: Wed Mar 16, 2011 2:44 am Post subject: 924 |
Will do.......got to find Plastigage first.
Hear NAPA carries it |
Posted: Wed Mar 16, 2011 3:48 am Post subject: |
Yeah, I think I got mine at Murray's... may be a bit of a PITA to spot, but they should have it... _________________ Vaughan Scott
Martijnus
Posted: Wed Mar 16, 2011 4:00 am Post subject: |
Did they grind the crankshaft? Since there isn't really a direct oversize available for bearings I doubt that...
If they didn't do anything to the journals, they're totally depending on the quality of the supplied bearings.
If they did grind the crankshaft, I sure hope they all have the same clearance, because that's how I'd do it. Measure bearings, determine desired journal size per journal, grind journals. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Wed Mar 16, 2011 4:46 am Post subject: |
| Martijnus wrote: | | Since there isn't really a direct oversize available for bearings I doubt that... |
gla924sem
Posted: Wed Mar 16, 2011 4:54 am Post subject: 924 |
Before checking on bearings......they reground the crank 10 under.....had to scrap that crank as none are available. They still billed me $110 for the regrind eventhough the crank was now junk. Would not budge even though it was their mistake!!!!!
Thanks to Ideola....he had a spare we pulled from one of his engines. Its been straighten and polished. |
Posted: Wed Mar 16, 2011 9:31 pm Post subject: |
Well, they'd have had to pay someone else to do the grind, so I can understand why they'd be unwilling to budge on that.
Then again, they scrapped your part thanks to not checking such things in advance...  _________________ Vaughan Scott
gla924sem
Posted: Wed Mar 16, 2011 10:19 pm Post subject: 924 |
Ideloa had a similar experience.....estimate vs actual cost at the end.
Did get some checking done last night on the block.......checked the new rings in the cylinder bore for end gap. All four came in well within spec.
Minimal wear on the bores even after I would say is 170K miles on that block.
Did not get to the mains or con rods last night. Looks like Thursday night for that task.
FYI-O'Rielly's/Murrays does carry PlastGage. They had it in two sizes.....red & blue.
Anyone interested in a 10 under crank?????
Willing to make you a good offer..... |
Posted: Wed Mar 16, 2011 11:33 pm Post subject: |
| Rasta Monsta wrote: | | Martijnus wrote: | | Since there isn't really a direct oversize available for bearings I doubt that... |
.25 over are NLA from King now. They won't be doing another run unless someone ponies up for 100 sets, and last I spoke with EBS, they had no appetite for it.
I have one set of Glyco .50 bearings on the shelf that I discovered at the bottom of a box in a parts lot I acquired a couple weeks ago. So oversize bearings are in fact a real problem at the moment. _________________ erstwhile owner of just about every 924 variant ever made |
TJC
Joined: 04 Apr 2010 Posts: 828 Location: Northwestern-ish Arizona, USA
Posted: Thu Mar 17, 2011 8:43 am Post subject: |
Herein lies the problem with machine shops and their customer's (and certainly no offense meant to the OP or anybody else) who rely on building an engine to "Tolerance" vs "Specification"
I'll limit my comments (maybe) to rod, rod bushing, and main bearing clearances, but many others apply.
Every engine whether it be built for "street" use or "race" use has an optimum specification within the manufacturer's tolerances to which the clearances should be held to. This even varies, for instances in a race engine, if the engine is to be used as a "qualifier", set up for "sprint" distances or "endurance" purposes. Again, for the proposed purpose the theory remains the same.
To achieve this result requires extra time and expense, but the results are enormously beneficial.
A short list of what should be done is as follows:
The machine shop should be provided with (at minimum) the block with main caps, the crankshaft, the rods, the piston pins, the rod and main bearings, the rod bushings and the specifications to perform the proper machining for the intended purpose...although I would personally shy away from a shop that did not have this knowledge for the given make, Porsche in this case, myself! And ALL components must be checked for viability in a rebuild!!!
Starting with the crank, it should be magnafuxed, checked for straightness, scoring, dimensions, etc. If it needs to be ground, that should be determined prior to buying any parts!
Then with the block, the main bearing bores must be checked to see if they are within specification, NOT tolerance, and be corrected by align honing or align boring.
The connecting rods will probably need re-sizing and re-bushing. This also should be done to specification, NOT tolerance, and the rods should be corrected to achieve equal center to center lengths as well at this time.
The bearings for the mains and rods should be installed, DRY, into the block and rods and the bore diameter should be measured...preferrably with a quality dial bore gauge.
The crankshaft, after polishing (if needed), should be again measured and then those rod and main diameters may be subtracted from the previously measured bore diameters to determine the bearing clearances.
If adjustments need to made, (albiet in the slightest amount) the rods may require additional resizing as well as the main bearing bores. This is required if measurements (preassembly) had not been done prior to machining initially.
There is actually a lot more work that is involved if attention to detail is important to you, but what I briefly explained is a small part of the blueprinting process that takes place in building a quality engine.
Also, I personally would chuck the plastigage idea, it may be okay for a Briggs and Stratton lawnmower engine, but for an engine that may see 6000+ RPM I think it is useless. If nothing else is available get yourself (or borrow) a good quality dial caliper that reads to the 0.0000" and measure your bores (with bearings installed of course) and crank diameters and get a truer reading of your bearing clearance.
Let me stress that these type of procedures are not only important on race engines, but street and tow vehicle engines as well if you desire longevity and decent performance. We've all heard about the factory built engine in a particular vehicle went forever and performed just great (no matter what the make) and that it must have been built "midweek" or was in the "sweet spot". This is one way that you can achieve this when rebuilding your own engine...no rocket science or magic required!
One quick question since your're going through this whole rebuilding deal...did you have the assembly balanced?
Oh, I should add that of course that the rod and main bearing caps must be torqued to spec when taking your measurements. The rods should be torqued while being in held in a rod vise preferrably, or if that is not available one can use a normal vise, with soft jaws, if it is large enough to grip the rod without interference from the vice "screw". The rod should be clamped very near the parting line. It is not generally advisable to torque the rod cap to the rod without the vise as it may be possible to twist the rod if excessive force is exerted upon it. _________________ '95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com |
Posted: Thu Mar 17, 2011 12:46 pm Post subject: |
^great post _________________ Toofah King Bad
