Jakkq
Joined: 29 Sep 2008 Posts: 810 Location: Omaha, Nebraska
Posted: Sat Mar 19, 2011 8:57 am Post subject: Argh! I Suck! |
I can't get anywhere! Days and days of trying to get the piece of shit oil filter off and it hasn't budged. I want to turn the car over and take an axe to it!!!
I have tried everything from pliers, screwdriver impact, oil filter wrench, the belt trick, the swivel oil filter grasping tool, hammer, fist, and plenty of PB blaster and such.
I need to get to one of the bolts to remove the Alternator, but I cannot get to it without removing the oil filter, which now has a hole in it, and it has had so much force and pressure turning that it literally dents every time I put too much pressure on it. _________________ 1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/ |
Posted: Sat Mar 19, 2011 10:07 am Post subject: |
Get a long bladed screwdriver and put it all the way thru the filter.
grab the handle and twist the filter off..  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Sat Mar 19, 2011 10:23 am Post subject: |
When I get stuck, I just call my dad  _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
Jakkq
Posted: Sat Mar 19, 2011 11:12 am Post subject: |
I can't use the screwdriver anymore. Like I said, the filter has had tons of pressure on it, and it's just denting in. I have a hole through the filter, but if I try and twist it with a screwdriver, it's going to tear at the filter and rip in two like a pop can. _________________ 1979 Porsche 924- Snailshell
jacob
Posted: Sat Mar 19, 2011 11:20 am Post subject: |
| At this point, you have tried everything else, maybe it would not be a bad thing if you tore off the outer tin can so that you can get to the mounting plate of the oil filter. If you have an old filter around. tear it open first and see if that might help you. |
Jakkq
Posted: Sat Mar 19, 2011 11:56 am Post subject: |
I'll give it some more tries tomorrow. Between this and stuck bolts and screws, I can't seem to get anywhere at all. Ugh. _________________ 1979 Porsche 924- Snailshell
Posted: Sat Mar 19, 2011 12:07 pm Post subject: |
| Yeah, I'd be at the rip-tear-shred phase at this point. Probably not going to damage the threads, but you'll just destroy the filter housing, which I think is probably what you want. Once you break the seal, it'll come off. |
jacob
Posted: Sat Mar 19, 2011 12:25 pm Post subject: |
Most filters have a set of holes around the top.
If you have a set of long nose angled pliers around, you might be able to get the nose of the pliers into the holes and get enough leverage to get the mounting plate off.
Hope this helps.
Good luck!  |
Joined: 29 Jul 2001 Posts: 9114 Location: Royal Oak, MI, USA
Posted: Sat Mar 19, 2011 9:24 pm Post subject: |
I've on some occasions had to use a screwdriver and hammer to start that plate turning, after ripping the rest of the filter out of the way.
That's why I always pre-lube the filter threads and seal now, so the oil filter is less likely to jam on. _________________ Vaughan Scott
924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Sat Mar 19, 2011 11:33 pm Post subject: |
Did you turn it the other way to help crack the seal first ?
Try spraying WD40 on and let it soak overnight.
Whats the brick trick , is that the same as when you want to loosen a screw you rap it on the screw head first with a hammer ?
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1998 Nissan Silvia ... sons back from OS he has taken it
BIG BLOODY MOTORHOME 300zx Sold
1980 Fire truck Sold |
Posted: Mon Mar 21, 2011 8:44 am Post subject: |
had same problem, bashed big screwdriver all the way through. casing tore but it came off as a big mangled chunk. _________________ Porsche 924 1984 (UK import) NA
mikebola
Joined: 07 Sep 2009 Posts: 361 Location: Parkside, PA
Posted: Mon Mar 21, 2011 8:57 am Post subject: |
Can you fit any kind of oil filter wrench onto it? I have 3 kinds I use in my shop (the socket, the band, and the chain wrench) _________________ proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs... |
the_mad_electrician
Posted: Mon Mar 21, 2011 9:34 am Post subject: |
| mikebola wrote: | | Can you fit any kind of oil filter wrench onto it? I have 3 kinds I use in my shop (the socket, the band, and the chain wrench) |
Chain wrench for an oil filter?!? Holy crap Batman!  _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Slam
Posted: Tue Mar 22, 2011 1:35 am Post subject: |
As above - cut filter body off, leaving mounting flange. Get a hammer and big screwdriver. Notch the filter flange and drive it counterclockwise with the hammer & screwdriver.
Interesting probelm. _________________ '88 944 Auto - may or may not resurrect |
