tyfighter123
Posted: Mon Mar 21, 2011 5:27 am Post subject: What can be used from 924S to 924? |
I have a 924S parts car and am wondering what all could be used or should be used from the newer 924S to put on my 924. So far I have done the 5lug conversion. Power windows and interior parts will be used as well. Can the radiator be used? The heater? Let me know. Thanks Guys _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 924S 1987 (parts car)(cut up and recycled)
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car) |
Slam
Posted: Tue Mar 22, 2011 1:30 am Post subject: |
Maybe the issue could be addressed in reverse - what CAN'T be used.
Off the top of my head, you can't use the engine and related ancillaries, clutch setup, radiator, heater (unless you're handy with fabbing things up), steering rack, transmission & torque tube. That's about it. Everything else will swap right over, but you're left with transferrring mostly body/interior stuff. What year 924? _________________ '88 944 Auto - may or may not resurrect |
tyfighter123
Posted: Tue Mar 22, 2011 2:41 am Post subject: |
Slam, its a 77'. I am planning on switching most of the interior over as its newer and in better condition. Would switching the heater be worth it? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Posted: Tue Mar 22, 2011 4:12 am Post subject: |
Late VHAC system works much better, might be a tough swap, though.
I think you should go for it and document the project for the Board! _________________ Toofah King Bad
tyfighter123
Posted: Tue Mar 22, 2011 4:55 am Post subject: |
Rasta, Im going to measure things and see if its a possible fit, ill keep it documented for the board. Anyone done this before? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Posted: Tue Mar 22, 2011 5:10 am Post subject: |
Torque tube, transaxle, shift-linkage and axles will swap over with the appropriate clutch disc to mate the 924 NA engine to the 924S (944) splines. Luckily the 77 used an Audi 4-speed which is pretty similar to the Audi 5-speed.
The gearing may not be the greatest for the 2.0L, but a quick perusal of a 944 gear chart should tell you what you may end up with or what you may want to trade up to
Body parts can interchange, maybe see if the hatch on the S is in better shape than the 77? Some of the later cars received an electric trunk release, which might be nice to have along with a rear wiper (if so equipped)
Grab one of the bulb holders from the 924S taillight housings and wire in an extra brake light for the rear.
Depending on the year, I think the fuel tank might be larger on the 924S, so it might be a good upgrade for long road trips. There might be some fabrication needed for the different mounting points for the larger tank. I think Rasta did it on his 931. Not sure if the 77 will have the same ability to be upgraded as it might have been a running change in the chassis.
Good luck with the parts swap! _________________ Stefan
tyfighter123
Posted: Tue Mar 22, 2011 5:35 am Post subject: |
Fiat22turbo, thanks for the info, so how hard, and what would need to be fabricated for the transaxle switch? Just a clutch kit for a 924S or do I need to make a bell housing? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
tyfighter123
Posted: Tue Mar 22, 2011 5:36 am Post subject: |
Rasta, do you think the tank would be a fairly easy switch? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Posted: Tue Mar 22, 2011 5:46 am Post subject: |
Tank swapping is a PITA. However, 924S uses the early style steel tank, which is very likely the same size as the one you have. _________________ Toofah King Bad
Posted: Tue Mar 22, 2011 9:05 am Post subject: |
| Rasta Monsta wrote: | Late VHAC system works much better, might be a tough swap, though.
I think you should go for it and document the project for the Board! |
http://www.924board.org/viewtopic.php?t=21849&highlight=924s+heater+conversion
13968 _________________ White 87 924S "Ghost"
Posted: Tue Mar 22, 2011 3:19 pm Post subject: |
| tyfighter123 wrote: | | Fiat22turbo, thanks for the info, so how hard, and what would need to be fabricated for the transaxle switch? Just a clutch kit for a 924S or do I need to make a bell housing? |
Nothing that extravagent, use the stock 924 NA bell and pressure plate with the 924S TT and a clutch disc with the proper splines. I've heard that some Chrysler discs have the proper splines. Should be a posting here about that someplace.
The rest is just putting the parts on the car. _________________ Stefan
Slam
Posted: Wed Mar 23, 2011 1:46 am Post subject: |
I probably should have qualified the tranny/torque tube thing. Above is correct (although I haven't come across a part number for the right clutch disc) but the 924S torque tube and tranny use the larger drive shaft, which won't just bolt up to the 924 NA motor. That makes the swap a project rather than a weekend upgrade. _________________ '88 944 Auto - may or may not resurrect |
tyfighter123
Posted: Wed Mar 23, 2011 9:36 am Post subject: |
Ok I just got done taking the MC and Vacuum Booster out of the 924S for the brakes. Two questions:
1. can I just bend the existing lines to reach the MC and leave them routed as they are? Or do I need to change the configuration?
2. Can I use my existing Vacuum Booster or do I need to use the 924SVacuum Booster. If I need to use the 924S booster do I need to adapt anything or will it mount right up?
I also took out the heater box and will be looking to adapt it to fit the 77, thanks for the link Paul.
And finally is the correct clutch disc the only thing I would need to make the 924S trany and torque tube work? Or do I need to modify anything else? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
