Posted: Wed Apr 13, 2011 4:08 am Post subject: DME Rev Limiter? |
Does it have one? What is the behavior? Would it be the "BAP BAP BAP BAP BAP" we all know and love, or a longer shutdown?
(yes, my new motor has finally seen 6k+) _________________ Toofah King Bad
Posted: Wed Apr 13, 2011 4:23 am Post subject: |
it happend to me once...it was a longer shutdown...if it werent for the seatbelt i would have had tasted the steering wheel as i was in first gear  _________________ Supercharger and EFI kits
Posted: Wed Apr 13, 2011 4:41 am Post subject: |
So its more a fuel cut-out. Interesting. I'm guessing it hits around 6500RPM?
My non-Porsche turbo car does this when the boost level spikes too high or you hit the rev limiter, it is terrifying the first time it happens and yes you do feel as though you'll be eating steering wheel  _________________ Stefan
Posted: Wed Apr 13, 2011 4:45 am Post subject: |
Morghen, that is exactly what happened, and I probably would have hit the wheel if not belted.
Either a fuel cutout or a ignition kill that took a moment to reset. It was around 6300 RPM, and I am trying to decide if it is a pump power supply problem.
Think I'll run the pump from a secondary relay, since the battery is inches away from it now.
Thanks for the replies, and other ideas still welcomed. _________________ Toofah King Bad
Posted: Wed Apr 13, 2011 7:37 am Post subject: |
The other possible cause is a torn wg diaphragm, and triggering of the overboost cutout switch. Both this and overreving result in fuel cutoff for 931s that were delivered with cats and o2 sensors.
RoW cars could and did use the rev-limiting rotor to cut ignition instead for overrev protection.
Cat-equipped cars (US, etc.) got the pricey $90+ fp relay with overrev sensing and fp cutout built in. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Apr 13, 2011 8:40 am Post subject: |
Interesting info, Smoothie, thanks. So the DME relay must have a solid state component that kills the fuel pump power on overrev.
FWIW, I have no overboost switch, and my WG doesn't have a torn diaphragm, because it looks like this:
Posted: Wed Apr 13, 2011 5:24 pm Post subject: |
i think you can still get overboost even without a torn WG diaphragm.
my car is ROW and apart from the fact that it does not use one of those relays you guys have...at the moment i had that engine shutdown experience i was runing a normal 12V relay instead of the fuel pump relay. So the over-rev or boost cut off must have been comanded by the DITC. _________________ Supercharger and EFI kits
jazz guy
Posted: Thu Apr 14, 2011 12:59 am Post subject: |
Rasta, I am not the ultimate authority on this but I am quite certain that as Smoothie stated, our US cars have a fuel cutoff rev limiter through the relay... and when it kicks in under boost, it hits HARD. It's definitely not a soft limiter where the revs stay up, gently bouncing off the limit, like newer vehicles.
When I purchased my 931, a college buddy of mine had an identical silver and black '82... We spent some time tracking the rev limiter down because my car would slam into the limit at just over 6100 rpm. This definitely put a damper on the fun factor. So we, I should say HE (he was finishing his master's deg. in EE), traced it back to the relay, tore the relay apart, and tweaked it to raise my rev limit. It's been 25 years ago, so I'm not positive, but I don't think it's totally a solid state circuit that controls it. I think I remember him talking about a mechanical spring in there... but again, that was a looong time ago...
| morghen wrote: | | my car is ROW and apart from the fact that it does not use one of those relays you guys have...at the moment i had that engine shutdown experience i was runing a normal 12V relay instead of the fuel pump relay. So the over-rev or boost cut off must have been comanded by the DITC. |
I'm pretty sure, at least for US 931's, that the ditc does not control overboost or rev limit. I believe Shaggy is an '80 model so it doesn't have a ditc.
Cheers, Brian _________________ '81/'81/'82 |
Posted: Thu Apr 14, 2011 1:23 am Post subject: |
My Geocities pics from then are long gone, but here's the link to where the various 924-931 fp relays were discussed - http://www.924board.org/viewtopic.php?t=10360
Quite a lot of electronic components are packed in there (the 931 rev-limiting relay) including 2 circuit boards, 2 timer ICs and a potentiometer or variable resistor which we guessed was the adjustment for the rev limit. _________________ "..it's made in Germany. You know the Germans always make good stuff."
RC
Posted: Sun Apr 17, 2011 11:03 am Post subject: |
Pity your pics are gone Smoothie, and not archived in cyberspace either. Do you not still have the originals to upload elsewhere?
This relay definitely needs some modifications or throwing in the trash. Are you guys crazy, 6100, 6300 maybe? F that!
Sounds like another of Porsche`s tricks to advantage the 911. The pussy relay. Ba ha ha aa ...
Another advantage to running MS, programable ignition or anything else but stock, even a MSD. _________________ World`s quickest 924 2L slushbox
