What's the wire running to my LF wheel bearing?
Brendan
PostPosted: Fri Apr 29, 2011 10:35 am    Post subject: What's the wire running to my LF wheel bearing? Reply with quote
What is the large wire running to my left front wheel bearing area? I didn't climb under to look at it real close. I did look though the parts catalog, and I can't see any indication of what this wire is. It runs into the engine compartment and through the firewall behind the instrument cluster.
My best guess is a heat sensor for an idiot light in the dash.
Thanks,
Brendan
PostPosted: Fri Apr 29, 2011 11:06 am    Post subject: Reply with quote
Its the speedo cable I believe.
Brendan
PostPosted: Fri Apr 29, 2011 11:32 am    Post subject: Reply with quote
Seriously? How odd if that's true. it's awful flexible for a speedo cable.
PostPosted: Fri Apr 29, 2011 11:58 am    Post subject: Reply with quote
How big around is it.
flosho
PostPosted: Fri Apr 29, 2011 12:17 pm    Post subject: Reply with quote
That's what she said?
Brendan.. How thick is it? Is it kind of stiff too?
My money is on the speedo-cable... all of my money.
[This Space For Rent]
PostPosted: Fri Apr 29, 2011 1:06 pm    Post subject: Reply with quote
Just like a Beetle
I think the early 911's did the same thing (which is still the same thing, HA!)
Runs through the upright, to the hub and clips onto the grease cap for the wheel bearings.
The grease cap has a square hole in the middle and the speedo cable has a tapered square end to fit snugly into the cap with a snap ring holding it in place.
Brendan
PostPosted: Fri Apr 29, 2011 2:31 pm    Post subject: Reply with quote
Girth.
After I clean up the coolant all over the floor, i'll have to get in there and see. If it's a speedo, that's a new one on me. though it's maybe not as strange as a fresh air intake for an alternator....
PostPosted: Sat Apr 30, 2011 3:49 am    Post subject: Reply with quote
Here's what mine looks like:
You can see the square drive dust cap (944 style) and the cable is just visible to the right behind the upright.
Here's the original 924 version:
Here's a shot of the cable running through my engine bay:
The cable is on the right, runs under the frame rail and steering shaft towards the LF wheel.
Brendan
PostPosted: Sat Apr 30, 2011 5:03 am    Post subject: Reply with quote
Yep, That's the one. Nice engine bay.
