Feltron
Joined: 11 Jul 2010 Posts: 44 Location: Port Murray NJ
Posted: Sat Jun 11, 2011 11:53 pm Post subject: Priming fuel pump |
My fuel pump recently went bad on my '78, I have the replacement and I have it installed however the pump cant get any of the gas out of the tank. The line behind the pump is bone dry, I've tried priming it by pouring gas into that line but to no avail. Is there any way I can prime the fuel pump so that it will have enough suction to start getting the gas moving? _________________ 89' Ranger with a custom front end and 924 bucket seats
78' 924 beggin to get on the track |
Brendan
Posted: Sun Jun 12, 2011 1:20 am Post subject: |
I recently pulled my fuel pump, and was surprised to see only a drip of fuel come out of the prefilter. I was prepared for a deluge, because the only thing that should have been slowing the fuel down was the prefilter.
As it turned out, the tank was full of sludge. I had to pull the sender to figure that out. Poke a rod down into the sump, if you can, and see if it's full of sludge.
Probably, you'll need to take off the plate at the bottom of the sump, and start digging out the sludge. Plan on a can of brake cleaner, nitrile gloves and compressed air to blow out the fuel line fitting. The sludge doesn't dissolve in gas, but brake cleaner will dissolve it. I pulled about a cup of sticky brown sludge from the tank sump. I bet this is what killed your fuel pump. |
Posted: Sun Jun 12, 2011 4:28 am Post subject: |
Theres a intank pump also...assuming of course the external is the 1 you
replaced. the tank can be dropped & cleaned also with out to much hassle. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Feltron
Posted: Sun Jun 12, 2011 5:20 am Post subject: |
I was under the impression that the 78 didn't have a in tank pump because that's what the tec section says. Ill try looking for the sludge in the tank but its brand new gas, the pre filter is clean and I can hear bubbles when I blow into the hose to the tank. Its rainy here today so I won't get to it till tomorrow but thanks all for the input. _________________ 89' Ranger with a custom front end and 924 bucket seats
the_mad_electrician
Posted: Sun Jun 12, 2011 6:40 am Post subject: |
My 77 did not have a intank pump but there were changes in 77.5 _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Sun Jun 12, 2011 7:22 am Post subject: |
Oh yea that's right my bad. _________________ 1979 porsche 924 Na
Feltron
Posted: Sun Jun 19, 2011 10:06 am Post subject: |
Thanks for the help everyone, turns out what happened was my fuel pump burnt out because someone siphoned my gas. It starts now... _________________ 89' Ranger with a custom front end and 924 bucket seats
