My Project Thread Fall 2010-Spring 2011
Goto page Previous  1, 2, 3 ... 9, 10, 11 ... 17, 18, 19  Next
PostPosted: Wed Jun 15, 2011 11:49 pm    Post subject: Reply with quote
oh, i know those cars, in some vids you might spot my 924
i go to see them race sometimes
http://vimeo.com/6036909
0:18 and some more later...i dont remember..
PostPosted: Fri Jun 17, 2011 9:09 am    Post subject: Reply with quote
wow.
flosho
PostPosted: Fri Jun 17, 2011 10:15 am    Post subject: Reply with quote
Sorry Morghen, I only made it :16 into the video. Then I paused it.
[This Space For Rent]
PostPosted: Fri Jun 17, 2011 10:28 am    Post subject: Reply with quote
You need Euro bumpers for that car, nice touch. Hey, I have some!
flosho
PostPosted: Fri Jun 17, 2011 10:35 am    Post subject: Reply with quote
I have a euro rear already, probably going something up front to make room for the FMIC that is already there.
flosho
PostPosted: Thu Jun 30, 2011 2:08 pm    Post subject: Reply with quote
PostPosted: Thu Jun 30, 2011 6:46 pm    Post subject: Reply with quote
sweet ! how thick is the sway bar on the rear?
flosho
PostPosted: Thu Jun 30, 2011 11:06 pm    Post subject: Reply with quote
I think it's a 19mm M030 bar... I can't remember now..
Stock front bar!
buldogo2
PostPosted: Fri Jul 01, 2011 1:01 am    Post subject: Reply with quote
sick build.
However...i think your exhaust will hit your drive shaft this whey.
PostPosted: Fri Jul 01, 2011 1:34 am    Post subject: Reply with quote
Stock front bar!
i have the opposite....on the front i have the 968CS one
PostPosted: Fri Jul 01, 2011 3:03 am    Post subject: Reply with quote
Way to go flosho. cant waite to hear how she runs. Very nice job there.
flosho
PostPosted: Tue Jul 05, 2011 9:06 am    Post subject: Reply with quote
Few random pictures:
Current condition as I will be pulling the motor next weekend...
PostPosted: Tue Jul 05, 2011 9:21 am    Post subject: Reply with quote
Very nice Jason, wish I had the mojo to go out and work on my junk.
flosho
PostPosted: Fri Jul 08, 2011 10:20 am    Post subject: Reply with quote
I'm looking to get things together this weekend.
I have a release bearing I got, that is technically used but has about <5000 miles on it.
Is there any way to tell for sure if the bearing can be reused or is it something that should be replaced anyway?
They are not really something that goes bad often are they? The one I pulled out of my car performed flawlessly.
flosho
PostPosted: Mon Jul 18, 2011 4:02 am    Post subject: Reply with quote
So the engine is back out so I can install the bellhousing/clutch/flywheel/etc.
I do have an issue now tho...
Timing belt had to be removed, flywheel was already off and now I need to reset the timing belt..
How do I get everything lined up without wrecking anything?
Is it possible to set the timing w/o removing the head?
I should be able to check the piston height in each cylinder.. If it is mid-way up the cylinder in all 4 cylinders I should be able to reset the camshaft so it is in the position it would be at TDC ( I vaguely remember there being a way to check based on the cam lobe position? )
After the cam is lined up properly, I should be able to set the bottom half to TDC w/o damage?
F*ck me, might as well just pull the head and rebuild the block with some custom pistons..
Also this is all due to the locating pin on the crank pulley shearing off..
Page 10 of 19
