Posted: Wed Jun 15, 2011 11:49 pm Post subject: |
oh, i know those cars, in some vids you might spot my 924
i go to see them race sometimes
http://vimeo.com/6036909
0:18 and some more later...i dont remember.. _________________ Supercharger and EFI kits
Posted: Fri Jun 17, 2011 9:09 am Post subject: |
wow. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
flosho
Posted: Fri Jun 17, 2011 10:15 am Post subject: |
| morghen wrote: | oh, i know those cars, in some vids you might spot my 924
0:18 and some more later...i dont remember.. |
Sorry Morghen, I only made it :16 into the video. Then I paused it. _________________ [This Space For Rent] |
Posted: Fri Jun 17, 2011 10:28 am Post subject: |
You need Euro bumpers for that car, nice touch. Hey, I have some! _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
flosho
Posted: Fri Jun 17, 2011 10:35 am Post subject: |
| Grenadiers wrote: | | You need Euro bumpers for that car, nice touch. Hey, I have some! |
I have a euro rear already, probably going something up front to make room for the FMIC that is already there. _________________ [This Space For Rent] |
flosho
Posted: Thu Jun 30, 2011 2:08 pm Post subject: |
Posted: Thu Jun 30, 2011 6:46 pm Post subject: |
sweet ! how thick is the sway bar on the rear? _________________ Supercharger and EFI kits
flosho
Posted: Thu Jun 30, 2011 11:06 pm Post subject: |
| morghen wrote: | | sweet ! how thick is the sway bar on the rear? |
I think it's a 19mm M030 bar... I can't remember now..
Stock front bar! _________________ [This Space For Rent] |
buldogo2
Joined: 13 Nov 2009 Posts: 79 Location: Nederland, Tilburg
Posted: Fri Jul 01, 2011 1:01 am Post subject: |
sick build.
However...i think your exhaust will hit your drive shaft this whey.  |
Posted: Fri Jul 01, 2011 1:34 am Post subject: |
| flosho wrote: | | morghen wrote: | | sweet ! how thick is the sway bar on the rear? |
Stock front bar! |
i have the opposite....on the front i have the 968CS one  _________________ Supercharger and EFI kits
Posted: Fri Jul 01, 2011 3:03 am Post subject: |
Way to go flosho. cant waite to hear how she runs. Very nice job there. _________________ 1979 porsche 924 Na
flosho
Posted: Tue Jul 05, 2011 9:06 am Post subject: |
Few random pictures:
Current condition as I will be pulling the motor next weekend...
Posted: Tue Jul 05, 2011 9:21 am Post subject: |
Very nice Jason, wish I had the mojo to go out and work on my junk. _________________ '83 944 Track car.
flosho
Posted: Fri Jul 08, 2011 10:20 am Post subject: |
I'm looking to get things together this weekend.
I have a release bearing I got, that is technically used but has about <5000 miles on it.
Is there any way to tell for sure if the bearing can be reused or is it something that should be replaced anyway?
They are not really something that goes bad often are they? The one I pulled out of my car performed flawlessly. _________________ [This Space For Rent] |
flosho
Posted: Mon Jul 18, 2011 4:02 am Post subject: |
So the engine is back out so I can install the bellhousing/clutch/flywheel/etc.
I do have an issue now tho...
Timing belt had to be removed, flywheel was already off and now I need to reset the timing belt..
How do I get everything lined up without wrecking anything?
Is it possible to set the timing w/o removing the head?
I should be able to check the piston height in each cylinder.. If it is mid-way up the cylinder in all 4 cylinders I should be able to reset the camshaft so it is in the position it would be at TDC ( I vaguely remember there being a way to check based on the cam lobe position? )
After the cam is lined up properly, I should be able to set the bottom half to TDC w/o damage?
F*ck me, might as well just pull the head and rebuild the block with some custom pistons..
Also this is all due to the locating pin on the crank pulley shearing off.. _________________ [This Space For Rent] |
