H.K. Johnston
Joined: 25 Jun 2011 Posts: 11 Location: Columbus, Georgia
Posted: Sun Jul 31, 2011 2:24 am Post subject: Fuel Pump |
No power to fuel pumps. Both new and wired correctly so it must be up from these connections. Fuses look good. Any Ideas Howard Johnston _________________ It ain't bragging if you've done it. 1982 924 turbo |
the_mad_electrician
Posted: Sun Jul 31, 2011 3:04 am Post subject: |
Check your ground it should be under the carpet in the hatch. There's a little bundle of connectors welded to the body there... _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Sun Jul 31, 2011 4:23 am Post subject: |
Also, remove the fuel pump relay and install a jumper across the two large pins. That should force the pump to run constantly. If not, then you know the circuit is energized and can trace it from there. _________________ Stefan
