Fuel Pump
H.K. Johnston
PostPosted: Sun Jul 31, 2011 2:24 am    Post subject: Fuel Pump Reply with quote
No power to fuel pumps. Both new and wired correctly so it must be up from these connections. Fuses look good. Any Ideas Howard Johnston
It ain't bragging if you've done it. 1982 924 turbo
the_mad_electrician
PostPosted: Sun Jul 31, 2011 3:04 am    Post subject: Reply with quote
Check your ground it should be under the carpet in the hatch. There's a little bundle of connectors welded to the body there...
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Sun Jul 31, 2011 4:23 am    Post subject: Reply with quote
Also, remove the fuel pump relay and install a jumper across the two large pins. That should force the pump to run constantly. If not, then you know the circuit is energized and can trace it from there.
