924 RELAY CONNECTIONS HELP
pimpi1976
PostPosted: Sun Aug 07, 2011 12:51 am    Post subject: 924 RELAY CONNECTIONS HELP Reply with quote
Hello colleagues, today I was sanding the connections of the relays and fuse box, everything was perfect when I was trying to clear an area of ​​difficult access, when it suddenly drops a relay and the car does nothing, the cables are: black, red / blue, red / black, brown. And it does not connect now put pictures of the wires and relay a greeting and thanks
stevekat
PostPosted: Sun Aug 07, 2011 3:23 am    Post subject: Reply with quote
There is no block or single connector to plug into? You just have four wires, each with a female spade connector attached?
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
pimpi1976
PostPosted: Sun Aug 07, 2011 4:25 am    Post subject: Reply with quote
Hello, I have not only each wires connector indepent
924aussie
PostPosted: Sun Aug 07, 2011 8:43 am    Post subject: Reply with quote
pimpi1976 wrote:
Hello, I have not only each cable with a
Alan
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold
pimpi1976
PostPosted: Sun Aug 07, 2011 11:32 am    Post subject: Reply with quote
I have four wires, each with a female spade connector attached?
stevekat
PostPosted: Sun Aug 07, 2011 4:16 pm    Post subject: Reply with quote
That looks like a standard off the shelf relay. It does not appear to be set up as a fuel pump relay as it does not appear to have the pulse signal wire (though I have seen set ups that omit this.) I'd look at the wiring schematic for the two multi-colored wires and see what they reference.
Are the female spade connectors factory or installed later by someone.
Did the relay fall out completely, without wires attached, and you believe they were attached before? That seems strange. Four wires simultaneously becoming disconnected?
This may not be the source of your car not running.
BTW, what do you mean when you say the car does nothing? It doesn't crank, doesn't start, doesn't have any power at all to any systems, gauges, lights, etc?
924aussie
PostPosted: Sun Aug 07, 2011 5:34 pm    Post subject: Reply with quote
Stacks and Stacks of info on these when you do a google.
Google ...... relay 86 87 85 30 porsche 924
Where was the relay ? I gather it was in the Engine bay or under the dash and does it have a bosh number like any of the below
From the Ferrari Board:
* BOSCH 0 332 014 113, quantity 14
These are 12V, 30A relays. They have a single #30 input, which connect two two #87 outputs. There is no normally closed output (i.e., no 87a).
* BOSCH 0 332 204 101, quantity 6
These are 12V, 20/30A Standard SPDT relays. They have 85, 86, 30, 87, and 87a terminals.
* BOSCH 0 332 015 006, quantity 1
[This has a big "K" labelled through it, which I have seen elsewhere on this type of relay]. 85 and 86, 30, 87, and 87b terminals.
pimpi1976
PostPosted: Sun Aug 07, 2011 6:24 pm    Post subject: Reply with quote
Hello, the reference of the relay is: 0332014125 12V/30A I've been searching google and I put fuel injector relay combination, I have him removed dash relay I met online but out of the relay box, but joined the group of original wires
what car do not hear when the ignition is the fuel pump
relay fuel pump that I have been looking into new
haynes manual and can not find
thank you
pimpi1976
PostPosted: Sun Aug 07, 2011 6:32 pm    Post subject: Reply with quote
forgive me for English
924aussie
PostPosted: Sun Aug 07, 2011 7:52 pm    Post subject: Reply with quote
this relay is used for a couple of things in the 924, fresh air blower, flashing blocker relay, power window relay, cooling fan, horn relay etc, still trying to find the right wire colour combinations, so
Starting from scratch ......
Is it a porsche 924 na or turbo ?
What year model is it ?
If it is a 1976 to 19771/2 model the haynes manual (page 246 ) is harder to understand where the relays are compared to the rest of the models
Alan
RC
PostPosted: Sun Aug 07, 2011 7:58 pm    Post subject: Reply with quote
That does not appear to be stock wiring. Possibly could have been for an immobilizer if "car does nothing". Could equally be a rewired by the PO nightmare. Its very time consuming but easy to check your circuit for someone with auto electrical knowledge and a meter.
Or take the easy way, an educated guess:
thinner wires to coil, 85,86. Doesn`t mater which way.
Thicker wires to NO contacts, 30, 87 , dont matter either.
Simply bridging the larger wires will reveal if "car does anything".
Allan @ DTA wrote:
924aussie
PostPosted: Sun Aug 07, 2011 8:13 pm    Post subject: Reply with quote
Slightly OT but
RC,
And any other Aussies,
If you want a good text book (s) pick yourself up these approx $200 Australian Books used by unis and the TAFE. 1500 pages
Automotive Mechanics (2 Volume Set)
Ed May
The 8th edition of Volumes 1 and 2 of Automotive Mechanics covers principles, applications and general servicing requirements that relate to passenger and light commercial vehicles.
It contains fully Australian content and standards and is completely updated with the latest developments in new automotive technology, digital and audio technology, workshop safety and environmental issues.
Alan
pimpi1976
PostPosted: Sun Aug 07, 2011 10:19 pm    Post subject: Reply with quote
Alan
My model is 1983
924aussie
PostPosted: Mon Aug 08, 2011 9:48 pm    Post subject: Reply with quote
My model is 1983
The Haynes manual I have only covers the 924 and turbo .... 1976 to 1982
Does anyone have a schematic for a 1983 and later ?
Alan
stevekat
PostPosted: Tue Aug 09, 2011 3:05 am    Post subject: Reply with quote
I would think your '83 is the same as an '82, and that it wouldn't change materially until the 924S.
