924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Mon Aug 15, 2011 1:16 pm Post subject: Suplementary Start Valve picture required please |
Has anyone got a picture of the wires as they are connected on the start valve , just want to check mine , this is only on some models . I am after the other side to this image
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
Muz924
Joined: 21 Jul 2010 Posts: 137 Location: Melbourne Australia
Posted: Mon Aug 15, 2011 8:59 pm Post subject: |
Hi Alan,
Is this what your after ? This is from my 1980 Aussie Spec.
From above......
From Below....
Cheers
Santo _________________ 1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car) |
924aussie
Posted: Mon Aug 15, 2011 9:15 pm Post subject: |
Thank you, it appears that the yellow with red trace is more to the centre of the valve and the brown white is closer to the edge or is it just an optical illusion
Is there anysort of writing on the bottom of the valve that is covered up by the muck on mine ?
I am soaking the screw thread in WD40 now so that I can take it out, it is a bit tight in there at the moment and as it is connected to other fuel components I dont want to force it
Posted: Tue Aug 16, 2011 3:11 am Post subject: |
| ewww yuk |
Posted: Tue Aug 16, 2011 8:57 am Post subject: |
I dont think polarity is an issue with these solenoids. _________________ Porsche 924 1984 (UK import) NA
Muz924
Posted: Tue Aug 16, 2011 10:40 am Post subject: |
| 924aussie wrote: | Thank you, it appears that the yellow with red trace is more to the centre of the valve and the brown white is closer to the edge or is it just an optical illusion
[Alan |
No writing on the bottom of mine. Looks like both spade connectors are equally located on bottom. The brown on mine just looks closer to edge as both connectors are bent. Don't want to touch them as they will most likely fall off!
I just replaced them as I found them which is not necessarily the correct combo, although matches up with the way the wires hang. _________________ 1978 924 RoW 5-Speed (Current Project)
924aussie
Posted: Tue Aug 16, 2011 9:58 pm Post subject: |
OK I have unscrewed it and cleaned it up a bit.
FYI Mine has the following information on it
Pierburg 7.20525.01
Germany
12v 9250
another discussion on the forum lists a
Electric Solenoid: Pierburg 7.20525.01 12V 1328
924aussie
Posted: Thu Aug 18, 2011 10:40 am Post subject: |
| Ozzie wrote: | | I dont think polarity is an issue with these solenoids. |
Correct me if Iam wrong, which is usually the case, but doesnt a solenoid do something like open and close ?
If the wireing is the wrong way around would not the solenoid open when it should be closed and close when it should be open ?
staticsan
Posted: Thu Aug 18, 2011 11:50 am Post subject: |
| 924aussie wrote: |
If the wireing is the wrong way around would not the solenoid open when it should be closed and close when it should be open ? |
Solenoids are just electro magnets. Energise them and the bolt moves.
It is possible for a solenoid to move the bolt in the other direction if the coil is energised in reverse, but it is just as possible for the bolt to move in the same direction whichever direction. From what people are posting, I'd say the SSV is of the latter type. The symmetrical connections also suggest that.
Wade. |
ryanspud
Posted: Wed Jun 10, 2015 11:58 pm Post subject: |
Hey guys, I just seen this thread and the electric solenoid show in the pictures earlier is exactly what I am looking for.
Anyone has an idea where I can buy one ? My 1985 924 needs a replacement of it.
THanks[/quote] |
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1424 Location: Washington DC area
Posted: Thu Jun 11, 2015 2:05 am Post subject: |
That's the frequency valve which usually has up to a 50% duty cycle to adjust the mixture based on feedback from the oxygen sensor to the computer.
We have been able to modify our computer on the race car to drive the frequency valve between zero and over 80% if needed to achieve 12.8 CO readings throughout the rev range. _________________ 1979 924 NA race car H-Prod SCCA
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
Harm
Posted: Thu Jun 11, 2015 4:04 am Post subject: |
| Fifty50Plus wrote: | | That's the frequency valve which usually has up to a 50% duty cycle to adjust the mixture based on feedback from the oxygen sensor to the computer. |
Sorry, Chuck. That is not the US frequency Valve;
It's the ROW Solenoid Valve to help cure the hot start problems on the later cars.
@ ryanspud: Could you add type and year to your signature, and confirm what you have is a ROW 924?
Maybe you should try getting your hands on a second hand one by putting an add up in Cars and Parts Wanted/For Sale
Harm. _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
ryanspud
Harm
Posted: Thu Jun 18, 2015 5:10 am Post subject: Re: Porsche 924 1985 2.0Litre |
| ryanspud wrote: | | Hey my Porsche is a 924 model with a 2.0litr engine standard, manufactured in 1985. |
…so it was ment for the Rest Of the World since the US stopped taking in 92fours as soon as the 94fours came into the picture (1982).
| ryanspud wrote: | | What do you mean by ROW 924 please ? |
ROW : Rest Of the World
A ROW 924 wasn't intended for the North American continent, in short US (My apologies to Canada)
The US 924 is different to a ROW car…
in looks and engine.
Harm _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
ryanspud
Posted: Fri Jun 19, 2015 6:27 am Post subject: |
| Thanks for the information @Harm. Any ideas of where I can find the part I'm looking for, second hand or new ? Porsche shop does not have it for sale and to be honest I'm running out of options as I got no replies from some scrapyards and distributors I contacted. |
