daniel
Posted: Thu Sep 01, 2011 6:07 pm Post subject: Sway bar bushing |
Anyone have and want to sell or know of a source for front sway bar bushings for the early type bar. I need the bush that goes on the end of the bar and into the drop link.
I specifically need one made from polyurethane type stuff. Delrin is just too hard and is causing too many drams.
Cheers
Daniel
PS anyone know how to machine the polyurethane bush's? Got a set that have too small an ID _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Thu Sep 01, 2011 6:29 pm Post subject: |
have you ever tried these guys in Brisbane, we went to the factory many years ago and they make the parts there.
http://www.fulcrumsuspensions.com.au/
Make: PORSCHE
Model: 922 & 924
Series: Early models with pressed steel front wishbones
Production Date:
Available SuperPro PartsFront
Front
Control Arm-Inner Front Bushing
SPF0647K
Requires 1 kit per vehicle Single Kit Contains 2 Inner Tubes, 2 Bushings
Control Arm-Inner Rear Bushing
SPF0648K
Requires 1 kit per vehicle Single Kit Contains 2 Bushings
Sway Bar End Bushing
SPF1169-_ _K
Measure end of bar diameter, 20,21.5,22,23,24,24.5,25.4,26,27 & 30mm ava
Suspension Parts & Poly Bushings for PORSCHE 944 Coupe 1989 - 1991Make: PORSCHE
Model: 944
Series: Coupe
Production Date: 1989 - 1991
Front
Sway Bar To Lower Control Arm Kit
SPF2922-18K
Original Rubber bushing # 951.343.793.30 = Suits factory bar diameter 25.5 & 26.8mm with end size on bar of 18mm
Sway Bar Mount To Chassis Bushing
SPF2923-_ _K
Measure bar diameter, 20,21.5,22,23,24,24.5,25.4,26,27 & 30mm ava, Suits bracket 944 343 731 00
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold |
Posted: Fri Sep 02, 2011 1:04 am Post subject: |
Hey does he mean OEM type stuff? _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
daniel
Posted: Fri Sep 02, 2011 8:34 am Post subject: |
Thanks Alan
I had a thought last night of using Areldite to glue the bush into the drop link then try to machine it from there. If that dosnt work, ill give thse guys a shot.
Not Joe he dosnt mean OEM type stuff _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
