82' 924 Exhaust options
shaunster
PostPosted: Mon Oct 03, 2011 5:31 pm    Post subject: 82' 924 Exhaust options Reply with quote
Hi Guys
Coming from a Tdi backround I have no clue on what exhaust is best suited to the 2.0 motor in the 924.
I had a look over the weekend and saw there are 2 long silencers and then the back box.
I was thinking of going with a 57mm straight through, although I am not sure what sort of back pressure the motor requires and I am not keen on losing power.
Thanks
PostPosted: Mon Oct 03, 2011 6:39 pm    Post subject: Reply with quote
dont use a straigth pipe...the vibrations will scramble the thoughts in your head
shaunster
PostPosted: Mon Oct 03, 2011 7:22 pm    Post subject: Reply with quote
I reckon my thoughts are already scrambled lol...got any suggestions?
PostPosted: Mon Oct 03, 2011 7:55 pm    Post subject: Reply with quote
this is a NA engine, right?
then get the exhaust form a 944 and youre set.
Euro924S2
PostPosted: Sun Oct 09, 2011 3:00 am    Post subject: Reply with quote
Is the 944 bigger diameter? does it bolt upto the 924 down pipe?
Cheers, john
UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp
shaunster
PostPosted: Mon Oct 10, 2011 6:44 pm    Post subject: Reply with quote
Misison to find one, anyways budget is super tight at the moment so spending etc is all on hold at the moment
shaunster
PostPosted: Mon Oct 10, 2011 6:46 pm    Post subject: Reply with quote
Jeremy924
PostPosted: Wed Jun 27, 2012 3:38 pm    Post subject: Reply with quote
Will the complete exhaust system off of a 944 fit? Head to tail??
just wondering cause theres a 944 in my local junkyard and not a single 924 in the hole state that i could find.
my exhaust is trash, leaking and incomlete (long story)
1981 924 N/A
1999 Suburban 454
1989 BMW 525I
daniel
PostPosted: Wed Jun 27, 2012 4:41 pm    Post subject: Reply with quote
944 exhaust will not bolt up to the head, and I doubt it will join below the header, but could be wrong
1989 944 Cabriolet
