924turborox
Posted: Sat Nov 26, 2011 12:08 pm Post subject: I crashed...rear right suspension |
What do you guys think of
REAR AXLE LINK
U94433102200
Price: $275.00
from autoatlanta.com?
What other rear trailing/control arms do you guys know of on the market?
I can't find any others just yet
Thanks,
Richard _________________ 1980 porsche 924 turbo 5speed getrag gearbox |
joecitizennn
Posted: Sat Nov 26, 2011 12:28 pm Post subject: |
Not a good idea to impulse by from autoatlanta. They are well known for bending people over. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Posted: Sat Nov 26, 2011 12:44 pm Post subject: |
Swap to aluminum, there's a guy parting a 924S right here.
OR. . .I bet someone here will part with a steel one for $50 or so! _________________ Toofah King Bad
Posted: Sat Nov 26, 2011 1:08 pm Post subject: |
I have a pair I need to get rid of. _________________ Stefan
Ian89C4
Posted: Sun Nov 27, 2011 2:38 am Post subject: |
I also have a pair, they are, sadly, drums, but the arm is the same. Let me know.
I will let each side go for $40, with hardware and hard brake line (don't know if it is the same for the drum and the disk). _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Posted: Sun Nov 27, 2011 2:59 am Post subject: |
| Ian89C4 wrote: | | don't know if it is the same for the drum and the disk |
Yes. _________________ Toofah King Bad
the_mad_electrician
Posted: Sun Nov 27, 2011 3:05 am Post subject: |
I have a rolling chassis i'd sell you for $275, but you'd have to come to Georgia to get it :p  _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Sun Nov 27, 2011 7:15 am Post subject: |
| Rasta Monsta wrote: | | Ian89C4 wrote: | | don't know if it is the same for the drum and the disk |
Yes. |
If the question was regarding brake lines, they are bent differently between drum and disk, and so are different. _________________ 78 924 NA
5-lug |
Ian89C4
Posted: Sun Nov 27, 2011 7:35 am Post subject: |
Good point, makes perfect sense. _________________ Ian Edgerly
North Carolina
Current:
Posted: Sun Nov 27, 2011 9:05 am Post subject: |
DOH I thought you were asking if the trailing arm was the same!
924turborox
Posted: Sun Nov 27, 2011 1:01 pm Post subject: |
Will the rear trailing arms be the same between a 924 and a 931? _________________ 1980 porsche 924 turbo 5speed getrag gearbox |
Posted: Sun Nov 27, 2011 5:40 pm Post subject: |
Yes. They are the same between the two.
Early 931 used drum brakes, discs were optional, later cars got the discs by default.
It all just bolts together. Grab a 924 arm and bolt up your disc brake parts after you remove the rear suspension.
I would take the opportunity to refresh the rear bushings, etc. while you have the suspension out. _________________ Stefan
Slam
Posted: Thu Dec 01, 2011 6:44 am Post subject: |
I'd also suggest making a careful check of the CV axle on the side that got bent. A blow hard enough to warrant changing the control arm could also break the CV joint. I know 'cause the '78 924 that we turned into a racer had this problem. We swapped the control arm and then had to deal with a fractured inner race in one of the CVs (outboard, IIRC). _________________ '88 944 Auto - may or may not resurrect |
