new wheels, opinions....
stew
PostPosted: Wed Dec 07, 2011 11:19 pm    Post subject: new wheels, opinions.... Reply with quote
Trial fitted, I had suspected a little work being needed, but apart from a very slight rub on the caliper frame (easily fixed) they fit fine.
joejax
PostPosted: Thu Dec 08, 2011 8:43 am    Post subject: Reply with quote
Me like...what size are they? What size rubber you gonna go with?
I got nothin'
Uhhh...you got any pics?
PostPosted: Thu Dec 08, 2011 9:39 am    Post subject: Reply with quote
There are very, very few wheel styles that look good on these cars, IMHO. It's no secret I'm a fan of the cookie-cutters, and I feel only that style of thinner-spoked, five-spoke wheels actually suit the car. Wheels such as the cookie-cutters, classic Fuchs and at least one set of Ronal wheels I've seen.
I'd say the spokes are too thick those ones you have. But it's all a matter of personal taste and if you like 'em, well, that's all that matters.
These cars have a tough shape/style to match wheels to, I reckon. For example, I really like them wearing the original spiderwebs and yet I can't stand the look of the BBS basketweaves on 'em, even though some might argue they are very similar looking wheels.
joejax
PostPosted: Thu Dec 08, 2011 12:11 pm    Post subject: Reply with quote
It should be Okay...to each his own. Haven't been blasted too much for these...
I got nothin'
joecitizennn
PostPosted: Thu Dec 08, 2011 1:04 pm    Post subject: Reply with quote
My favorite wheels of all time are speedline cup. Doubt that I will ever spend 4000 for a set though.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
Horizonblue
PostPosted: Fri Dec 09, 2011 4:03 am    Post subject: Reply with quote
I have the same rims on my car.
7x16 with 225's in the front / 9x16 with 245's in the rear
By horizonblue at 2011-10-08
I plan to paint the spokes black and keep the edge polished. I think that will look good on a white car, maybe that will look good on yours too.
The spokes are a bit fat, yes, but they cover the drum in the rear, so that's fine for me.
Euro 924, 1976
/P.G. Andersen
PostPosted: Fri Dec 09, 2011 5:54 am    Post subject: Reply with quote
sorry stew...i think those wheels belong to the 199x BMW series 3.
Nein37
PostPosted: Fri Dec 09, 2011 9:02 am    Post subject: Reply with quote
Wow! 245s on a narrow body! Nice job squeezing those in. Looks pretty darn good. Can we see a side on shot of the car?
1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears.
PostPosted: Fri Dec 09, 2011 9:56 pm    Post subject: Reply with quote
Looks like some arch rolling front and rear has been going on to do so.
Raceboy
PostPosted: Fri Dec 09, 2011 10:51 pm    Post subject: Reply with quote
I ran 255/40 R17 tyres on both white and red 924 narrowbody without any rubbing or rolling. Wheels were late offset (52 iirc) Cup 1's from 964 Turbo (9x17).
Strangely this setup worked perfectly with stock 931/944 brakes with factory aluminium spacer but when I switched to 924S rear suspension with aluminium arms (still narrow hubs and rotors), it sticked further outside on both sides and it was not a camber issue. 924S rear suspension is around 10 or so mm's wider on both sides (~20mm wider track).
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Horizonblue
PostPosted: Sat Dec 10, 2011 3:43 am    Post subject: Reply with quote
I don't have a "side on" picture, when the car is standing on the ground. It is placed on jack-stands now, since I'm replacing the engine. But here is how that looks.
Euro 924, 1976
/P.G. Andersen
Horizonblue
PostPosted: Sat Dec 10, 2011 4:02 am    Post subject: Reply with quote
Actually no, but the front wheels WILL touch the steel inside the wheel well, when the steering wheel is turned all over, to the left or right.
On the rear axle, I had to flip the bolts that holds the upper end of the shock-absorbers, so the bolthead was facing the tyre, and I also did grind a bit of the boltheads away (just to be sure). These bolts were mounted with the nut facing the tyre, and in this case, the bolt-end could just touch the rubber now and then.
Actually, I will have to roll the rear wheel arch, to get rid of the 1/2 inch sheet metal flange, that goes along the arch, pointing inwards.
This flange WILL touch the rubber now and then.
Euro 924, 1976
/P.G. Andersen
stew
PostPosted: Fri Dec 16, 2011 11:06 pm    Post subject: Reply with quote
I like them and that all that matters
They'll be fitted to my silver/blue car and I think will suit that one much better than the brown car.
As for tyres, I'm not goiing as wide as horizon blue, I'm thinking either 205/50 to retain somewhere near the original rolling radius or poassible 195/50, it will be lower than standard too.
