Min
Posted: Fri Oct 14, 2011 12:26 pm Post subject: |
| RC wrote: | | It is outdated technology and WILL complicate the installation, tuning and reliability factor. |
Reliability? really? tuning? I strongly disagree with your conclusions on these points. You've made a claim, now provide concrete evidence to support your claim please. Also include the number of EDIS systems you've installed, and approximate time you've actually spent using the system. That way we can better understand your frame of reference.
RC
Posted: Fri Oct 14, 2011 2:32 pm Post subject: |
OMG Min, I`m not hopping on this EDIS roundabout again and going around in circles with you even if you still enjoy riding it. Clearly, you are heavily emotionally invested in this issue and fail to see things from a logical perspective. FFS, Ford dropped EDIS nearly 20 years ago and moved forward.
As most engineering students know, the more unnecessary hardware added to any system the greater the odds of failure. Basic design principle. Especially in an automotive environment of heat, moisture, corrosion, vibration and with additional wiring and connectors involved.
When MS can directly decode the trigger wheel input signal and then drive whatever coil(s) desired, (including EDIS coilpacks if desired) there are NO advantages of incorporating additional hardware that processes the signal through two stages to arrive at hopefully the same output. I realize the electronics is above your level of understanding Min, but recall posting some links previously that explain the basic operation. Perhaps have a re-read before replying?
Remember?
http://www.924board.org/viewtopic.php?p=309590&highlight=edis#309590
| RC wrote: | Getting back to EDIS, this similar problem will occur, (and others) albeit only half as bad since the tach pickup is crank (VS cam) driven. Depending on the configuration with MS this particular issue is compounded. The EDIS clock speed is only 250KHz. Reasonable for the 90`s though, just like analog brick phones were. IIRC MS1 runs at 4MHz and MS2 @ 20MHz.
http://www.dainst.com/info/edis/edis.html
http://www.vems.hu/wiki/index.php?page=EdisIgnition%2FFaQ
Yes, (Why do I think Min will jump in here??? ) |
http://www.924board.org/viewtopic.php?p=251998&highlight=edis#251998
http://www.924board.org/viewtopic.php?p=304516&highlight=edis#304516
Oh yeah, there is also the tacho issue, that most EDIS users here have experienced too.
Personally have no intention of wasting my time arguing the pros & cons of EDIS with a brick wall again. For the OP`s benefit, YES a cam mounted wheel is perfectly feasible. As previously suggested, ask, read & search here but particularly on the MS sites for your information, as ultimately it is your installation and your decision on how you proceed. _________________ World`s quickest 924 2L slushbox
Raceboy
Posted: Fri Oct 14, 2011 4:29 pm Post subject: |
I installed 60-2 wheel on the crank on my 931 "Gulf" and welded a 10mm wide tooth on the cam pulley for cam sync which is sensed by Honeywell 1GT101 Hall sensor.
That is because this way I get best timing precision (60-2 on the crank) and fully controllable injection angle. Yes, I use this on my 931 and it has noticeable benefits on engine smoothness and driveability, especially with the biggish 630cc injectors that I use.
If one has to install a trigger wheel anyway, I wouldn't bother putting it on cam because it will result in timing drift and resolution would be half compared to crankshaft mounted trigger wheel (same tooth count). _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Min
Posted: Fri Oct 14, 2011 11:33 pm Post subject: |
| RC wrote: | | FFS, Ford dropped EDIS nearly 20 years ago and moved forward. |
I see, you've moved to the insults, ok. EDIS was -introduced- in 1990. Do the math sir, thats 21 years ago. That it was introduced. EDIS has been used in mid 2000 cars. I would provide makes and models, but I forget which ones they were. After 96 the EDIS module was moved into the ECU case.
| RC wrote: | As most engineering students know, the more unnecessary hardware added to any system the greater the odds of failure. Basic design principle. Especially in an automotive environment of heat, moisture, corrosion, vibration and with additional wiring and connectors involved.
So, basically what your trying to say is ..... you've never used it, have no idea on its actual reliability or tunability. Since you've provided more generalizations as concrete evidence. Electronics are above my understanding? really? Did you read what you decided to post first?
You make statements about a system that ford has used for years, claiming it is unreliable. Then provide generalizations that 'every engineering student' should know. Simply becuase you picked a different path, don't come piss all over what everyone else is doing. Especially when you don't actually have any proof or knowledge to support your claims.
Dunno what I did to piss you off so much other than challenge your opinion. Perhaps you should take some deep breaths. I'm not a brick wall, you just refuse to actually provide evidence to support your claims. Probably becuase you have none.
Posted: Sat Oct 15, 2011 2:41 am Post subject: |
When choosing the ignition system for my EFI conversion. I decided that I wanted to go with a distributorless solution. Because of the potential for better ignition control (something the 924 desperately needs to maximize the amount of power under the curve) and because I really like the cleanliness of a distributorless solution.
I chose EDIS simply because it was a simple solution to install. Fairly self-contained, reliable, well documented and was a known quantity. The fact that I could simply connect the stock tach to the output of the EDIS module was a win to me. Also the fact that I can put the system in limp-in which fixes the timing at 10 degrees means that I have one less issue to fight during first start/basic idle tuning.
I know that the next step is to remove the EDIS module and drive the coil pack(s) directly from MegaSquirt, which does open the door to improvement on ignition control by improving finite control (among other things). However, to do that requires that I move to MS2 (at least) and that is a much larger jump from where I am now as I'd have to determine how to drive the tach from MS, how to translate my timing table over and start to make improvements, etc. I will get there as my goal is to see how far I can take this motor, but I need to make small steps at a time or it will never be driving.
So that is my reasoning, the choice to use EDIS or another ignition system is a personal one. Do your research and determine where your comfort level and ultimate goal is and go that route. _________________ Stefan
rx924
Posted: Sun Oct 16, 2011 1:50 am Post subject: |
I think i'm going to follow fiat's idea here. Use the EDIS for simplicity and making me run into less problems on my first startup.
Once i get the car running with the EDIS i can simply play with a ton of different ignition ideas since i've got everything else calibrated.
And wouldn't the best Crank or Cam position sensor be one that could be placed where the distributor mounts behind the valve cover? Something like what mazda uses on the 13b rotary's? Just wondering.
I'm glad people are answering my first post here!!!!!!!!  |
Min
Posted: Sun Oct 16, 2011 2:34 am Post subject: |
| rx924 wrote: | | Cam position sensor be one that could be placed where the distributor mounts behind the valve cover? |
In my opinion, the best location for the cam position sensor is were RC has mounted his, to the back of the cam gear.
Raceboy
Posted: Sun Oct 16, 2011 5:07 pm Post subject: |
It depends on the ECU which is simpler, EDIS or using IGBT's in the ECU.
With MS it may be easier to use EDIS, but most other ECUs already have IGBT's inside the ECU and how could be installing EDIS with its additonal hardware, proprietary ignition leads and precisely orientating the trigger wheel on the crankshaft easier than just using a generic Bosch coil-pack (cost: $40) and connecting three wire to it (+12V supply and two wires to ECU)?
The orientation of the missing tootl does not matter too much also as the trigger event (missing tooth passes the sensor) just has to happen the number of degrees that your max advance will be and not happen in the spark instant. You just fine-tune the missing tooth location with the strobe light and get absolutely the best precision. You can never get the angle between trigger event and TDC precise by measuring it with degree wheel because VR sensors sense the missing tooth differently.
Have you checked the spark angle with strobe light on the EDIS system to ensure that it is spot on? Should be 10 degrees BTDC without ECU input signal on the EDIS module, easy to check. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Min
Posted: Mon Oct 17, 2011 4:46 am Post subject: |
| Raceboy wrote: | It depends on the ECU which is simpler, EDIS or using IGBT's in the ECU.
proprietary ignition leads and precisely orientating the trigger wheel on the crankshaft easier than just using a generic Bosch coil-pack (cost: $40) |
Weither you install high powered ignition drivers is a build option when your assembling your megasquirt.
Your aware you can use generic coil packs with EDIS right? apparently not. Also, you don't have to be precise at all about your trigger wheel orientation, it can be pretty far out and still work fine. You just adjust the offset in software using a timing light, pretty simple. Instructions are in the EDIS installation instructions in the megamanual
Why did I go with EDIS? becuase when I installed my system 6 years ago, COP wasn't an option. All the triggering options using wheels etc had not been coded yet. I also didn't want high powered ignition drivers in my ECU case. Its a simple and reliable system. Vast improvement over distributor driven ignition.
rx924
Posted: Wed Oct 26, 2011 2:10 pm Post subject: |
Alright so my MS2 and mega stim have come in =)
I've put together the stimulator so far and i'm working on MS slowly when i have free time. I'll post some pictures soon i may make a new post just to show the whole project |
Raceboy
Posted: Wed Oct 26, 2011 4:26 pm Post subject: |
| Min wrote: |
Min |
Fair enough, and I haven't said anything about EDIS not being reliable etc. My point was that today it is much easier to obtain and install variety of other parts. I have many friends who use MS+EDIS on their cars and I don't know why they don't use generic coil-packs but instead source proprietary plug wires.
Regarding IGBT's in the ECU case, I am not that familiar with MS packaging, but with VEMS (and many other ECU's) there are no issues whatsoever with case mounted IGBT's. They are clamped onto case for cooling and even on Audi V8 running passive COP's on the race-track (constant 5000-7000 rpm) doesn't heat the ECU at all. It gets barely warm. No noise issues also.
It is just simple and works. BTW, BMW has 6 IGBT's mounted inside the ECU from the factory on its M50 engines.
And whatever DIS one gets, it's still miles better than non-controlled factory dizzy ignition  _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Min
Posted: Thu Oct 27, 2011 11:17 pm Post subject: |
| Raceboy wrote: | | Regarding IGBT's in the ECU case, |
Oh I'm sure its fine. At the time I was paranoid about it.
| Raceboy wrote: | And whatever DIS one gets, it's still miles better than non-controlled factory dizzy ignition  |
Yes, yes it is.
rx924
Posted: Thu Dec 22, 2011 9:11 am Post subject: |
This is my throttle position sensor. It uses a standard potentiometer with a servo cross attached to it. From the servo cross a bar goes to the axel that rotates from the throttle body. Almost all the parts i used from a hobby RC car box of parts. |
rx924
Posted: Thu Dec 22, 2011 9:44 am Post subject: |
This is a 3D model of what my entire crank pulley will look like once my lathe/mill comes in.
This is what i'm using to hold the trigger wheel to the crank pulley. The piece in red is what i am cutting out on the mill. I'm going to weld it to the pulley and then weld the nuts on it to make easier to bolt down. |
flosho
Posted: Thu Dec 22, 2011 9:49 am Post subject: |
One thing you may want to consider is how the trigger wheel is bolted to the crank pulley.
You have the elongated holes running from the center towards the edge, but this only gives you a limited number of adjustments. It also could lead to the trigger wheel not being perfectly centered on the crank pulley which could cause additional issues.
If the trigger wheel has slots in it that go around the wheel, you will have better ability to index the trigger wheel to the proper spot.
I believe that is how my trigger wheel is (from the original group buy) and many others with adjustable wheels use this method...
If your trigger wheel is pre-made I would look for a solid one and mill your own slots. _________________ [This Space For Rent] |
