rx924
Posted: Thu Dec 22, 2011 10:36 am Post subject: |
If i use four bolts though the trigger wheel will only be able to be placed in one spot with a small tolerance because the movement in each axis will be hindered by the other axes's bolts.
As for position i was thinking of making my VR sensor mount slightly adjustable. But you are correct i may need to buy a new solid trigger wheel. If its too hard to center it. |
flosho
Posted: Thu Dec 22, 2011 1:07 pm Post subject: |
Good point there, I did not consider that. I was thinking it would be much easier and allow a greater range of adjustment if you can spin the trigger wheel since the VR sensor should be mounted securely and there are few sufficient mounting systems. _________________ [This Space For Rent] |
