My Project Racecar
Goto page 1, 2, 3  Next
stuartbrs
PostPosted: Mon Sep 26, 2011 9:49 pm    Post subject: My Project Racecar Reply with quote
Thought I might put some pictures up of the project car. It was going to be just a clubday car but these plans change...
I should have saved my pennies and bought something that was running and in fairly good nick but then I would have struggled to pull it to bits and turn it into a racecar. 924`s arent all that common in Tassie and this one was cheap.. as you can see by the pictures..
Delivery day.. rough as guts!
That should buff out...
Sound deadener.... uuuuggghhhhh
I tried Dry Ice but was a bit dissapointed so it was out with the heat gun, a chisel, a scrapper, screwdriver, parts cleaner, rags, razors, scrubbing brush, wire wheel attachment, metho, acetone and beer.. Ive only got the passenger side to go...
Ive always wanted a bumper sticker that says "My other car is also a Porsche"...
Test fitting the A9X flares
We`re starting to seam weld it on the weekend, then getting the cage in and giving it a squirt of paint.. Oh, and hopefully, getting it to start..
In hindsight, I should have just stripped everything out of the shell and had it dipped.. but we want it on the track by december.. hmmm
To finish first, you must first finish!
daniel
PostPosted: Tue Sep 27, 2011 8:31 am    Post subject: Reply with quote
Good on you for scraping all the tar of the floor. I purchased my car in August and had it running in November, so what you are trying to do is not impossible. I did the following:
- Strip the interior, including tar
- Fit 2x OMP race seats
- We made our own cage, I made a sample cage from PVC pipe, took it to fabricator who made the bends up for me. We then cut and welded.
- Fitted 28mm torsion bars and 250lb springs, bilstiens all around.
- s/s brake lines
thats it, purchased the car for $6000, put another $5000 into it.
Good luck, let me know if you need any advise!
1989 944 Cabriolet
stuartbrs
PostPosted: Tue Sep 27, 2011 9:03 pm    Post subject: Reply with quote
Thanks Daniel, I`ll definitely be hitting you up for advice. I really want to run it in Improved Production depending on how we go with convincing CAMS that it should be so... there is a "Targa" class here in Tas I can run it in as well though.
Are you happy with that suspension setup? Once we`ve got the cage in I`ll be tackling the suspension.
chax
PostPosted: Tue Sep 27, 2011 10:22 pm    Post subject: Reply with quote
Hey ! Your parking lot just looks like mine
stuartbrs
PostPosted: Tue Sep 27, 2011 10:37 pm    Post subject: Reply with quote
Beautiful cars Chax!
chax
PostPosted: Wed Sep 28, 2011 9:54 pm    Post subject: Reply with quote
Thanx
hayeslewis
PostPosted: Thu Sep 29, 2011 11:37 pm    Post subject: Reply with quote
Beautiful work, I skipped it and bought a racer-but I admire it greatly. I've helped remove sound deadening on other cars, a truly miserable experience!
stuartbrs
PostPosted: Fri Sep 30, 2011 7:20 pm    Post subject: Reply with quote
To be honest, in hindsight, I would have been better off striping the car to a shell and having it dipped, then painted, then just install the bits it needs to be a racecar.
Ian89C4
PostPosted: Tue Oct 11, 2011 7:31 pm    Post subject: Reply with quote
Plus one on the miserable experience!!!!
I have been overseas for a bit so work has stalled on the racer project, but I feel you pain. I have all of the melt sheet out - but all of the resedue is still in there - that part I am dreading!!!!!!!!
Good luck!!
Looks great so far =-)
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
stuartbrs
PostPosted: Wed Oct 26, 2011 5:13 pm    Post subject: Reply with quote
Some more progress... trying to get the cage in before the end of the year so we can get it log booked..
Bit of pretty lights welding..
Stitching up the seams
Rear cage in.. still got to put the horizontal bar from left to right in though
Hopefully we can start on the front this weekend.. if the steel arrives in time...
stuartbrs
PostPosted: Thu Feb 09, 2012 7:57 pm    Post subject: Reply with quote
Well, its been a few months so here are some progress pics.
Cage almost complete
More of the cage
Front panels removed ready for a tidy up, and fitting a turbo badge panel
We got the engine running and it will do for a couple of Club days. Next phase is to pull all the suspension off and the gearbox out and then get it painted. Then reassembly...
stuartbrs
PostPosted: Thu Feb 09, 2012 8:00 pm    Post subject: Reply with quote
Oh, and yes, some of those welds look a bit ugly, we`ll clean them off and run another bead over them. We were having trouble with the welder.
Also, for the Aussies, I got the roll cage "grandfathered" under 2011 rules. Basically I paid my Cams fee`s and sent a heap of photo`s of the tubing and installation diagrams and got it approved in concept under the 2011 rules.
stuartbrs
PostPosted: Thu Feb 09, 2012 8:31 pm    Post subject: Reply with quote
Oh, and a quick video of the engine running...
http://www.youtube.com/watch?v=HWP-jBvDhzE&list=UUCX4gdcdcy8YEFHvUNngzvQ&index=4&feature=plcp
yes, noisy tappets...
lordam
PostPosted: Sat Feb 11, 2012 6:40 pm    Post subject: Reply with quote
What changes to roll cage design are coming in 2012 that you have been able to avoid by "grandfathering" into the 2011 regs?
1981 931 ROW RHD Australian delivery, Bilsteins, LSD, adj coilovers, #350/550lb/in front, 27mm TB, adj rear sway bar, Targa setup
stuartbrs
PostPosted: Sat Feb 11, 2012 7:32 pm    Post subject: Reply with quote
Not a lot actually...the roof only has the one center bar, 2012 rules say an X. And there is some measurent on the front legs which it turns out wouldnt make a difference to a 924/944 anyway. There was a lot of doom and gloom about 2012 roll cage rules but most it relates to rally cars and road rally cars.
Page 1 of 3
