porscheboy79
Joined: 25 Oct 2010 Posts: 65 Location: Sydney , Australia
Posted: Sun Feb 12, 2012 5:44 am Post subject: |
It's great to see it coming along.
I have been avoiding doing the cage for 2 years now and I have to finally do it.
what did you use to make the bends look so good?
I am worried that my pipe bender may leave more than the 90% rule elongation.
Any suggestions after your install?
regards Shane. _________________ 79 924. 100kph + wall at Mt Panorama = Gone.
77 924 SPIRIT project for racing. |
stuartbrs
Joined: 31 Aug 2011 Posts: 54 Location: Tassie, Australia
Posted: Sun Feb 12, 2012 8:47 am Post subject: |
Hi Shane
The rear was one I bought which was pre-fabed. We had to put a lot of reinforcing into the wheel arches area as Ive read on the boards that its not a good place for the rear bars to sit. We have a lot of 3mm plate around there and have bought it down to the box section. In hindsight, it would have been a lot easier to make that from scratch as well.
I bought all the front steel off one of the local guys here that makes ( really beautiful ) roll cages. We then got some old water pipe and made a template for the front legs with a normal pipe bender. The roll cage guy then bent the front legs ( $50 each ) on his mandrell bender to the tempalte we made. It took a fair bit of mucking about to get the shape right.
I followed the CAMS rule book as closely as possible hence the really big mounts we made on the box sections, but Ive since seen other "interpretations" which passed fine and didnt use such big mounts. There seems to be a lot of deliberate grey areas and contradictions in the roll cage rules. My mate has a Datsun 1600 and bought a BOND cage and only used one plate on the floor without the "feet" for the legs for instance.
All up the cage cost less than $1000. If I do it again though, I would make the whole thing from scratch, and start with a stripped and dipped bare shell. Even once we had cleaned off the galvanising the welder still spits and carries on in those areas.
We`re putting the last bars in this afternoon, so I will post some more pictures tonight. _________________ To finish first, you must first finish! |
stuartbrs
Posted: Sun Feb 12, 2012 8:51 am Post subject: |
Oh, and one more tip from my panel beater mate. When the car sits on axle stands it "droops" quite a lot. Older cars like the 924 arent to bad but modern cars ( particulalry Falcadores ) are terrible for it. If you have it on the stands for any length of time make sure you check that the doors are still closing properly... or even better, sit it on a cradle. _________________ To finish first, you must first finish! |
stuartbrs
Posted: Mon Feb 13, 2012 5:25 pm Post subject: |
Finally, the cage is in...
Front view
More
Hindsight is a wonderful thing... I dont regret buying this car in the slightest, I do however, think I should have stripped it completely and had it sandblasted, and then built the cage from scratch. I thought we could just install a cage, fix the bodywork and have a bit of fun club racing it... _________________ To finish first, you must first finish! |
stuartbrs
Posted: Sat Mar 10, 2012 4:22 pm Post subject: |
Some more, um, progress....
Well, the engine was leaking more and more each time we started it, and I wanted to paint the engine bay anyway so it was a good excuse to pull the motor
And I once it got to this height.. we realised where the leak was coming from, um, the oil filter was loose... doh.. oh well
I really want to fill this hole with a turbo...
stuartbrs
Posted: Sat Mar 10, 2012 4:29 pm Post subject: |
I must say though.. pulling a 924 motor is MUCH easier than pulling the motor from my other project car...
stuartbrs
Posted: Sat Mar 10, 2012 4:32 pm Post subject: |
Doesnt look complicated at all...
joejax
Posted: Sat Mar 10, 2012 11:59 pm Post subject: |
| stuartbrs wrote: | Doesnt look complicated at all...
Suh-weet!! _________________ I got nothin'
Uhhh...you got any pics? |
stuartbrs
Posted: Sun Mar 11, 2012 7:01 pm Post subject: |
And yes, Ive measured it all since I pulled the motor and the Quad Cam S4 Engine would easily fit inside a 924 engine bay, theres actually more room in there than there is in the 928... and no, Im not going to try!
Besides which, the quad cam motor isnt all that good for a racing car anyway. _________________ To finish first, you must first finish! |
stuartbrs
Posted: Thu Mar 29, 2012 8:09 pm Post subject: |
Well... one stripped engine bay... Hoping to get it painted over Easter.
stuartbrs
Posted: Fri Apr 06, 2012 6:56 pm Post subject: |
The steaming pile of excrement that is the wiring loom. This is going in the bin. I`m thinking of a universal wiring kit.
Oddly, with the doors off, its begining to look like a racing car...
stuartbrs
Posted: Fri Apr 06, 2012 7:00 pm Post subject: |
And for those that like this kind of stuff... the 928S has a new exhaust...
Its even throatier than the old one
stuartbrs
Posted: Sat Apr 07, 2012 3:23 am Post subject: |
Nice.  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
stuartbrs
Posted: Sat May 26, 2012 4:45 pm Post subject: |
Some more "progress"...
Not exactly clean enough to eat your dinner off... yet
