breaking up in mid range
bkantelis
PostPosted: Tue Mar 20, 2012 7:41 am    Post subject: breaking up in mid range Reply with quote
All,
On this loing journey with my 79NA I have flushed the fuel tank, replaced the pumps, wur and rebuilt the dizzy (did that myself). Idle is great and foot to the floor is great. Just can not run it in the middle, any gear at 3000rpm the engine is breaking up terrible, foot to the floor takes right off and sounds great.
Tested vacuum line that includes brakes and distributor and it was fine.
Any suggestions appreciated.
1979 NA 924
Georgia, USA
musicalannette
PostPosted: Tue Mar 20, 2012 9:55 am    Post subject: Reply with quote
Hi,
Full advance from the spark it there by around 3 or 4000 revs usually, so as it works fine foot to the floor and idle, try and accelerate foot to the floor from 2000 to 5000 and see if its ok, if it is then I would look at it as a fueling issue. With tickover being fine, I would think it is not a problem with air leaking in, and as the thing is ok at full throttle, I would think the fuell supply and injectors are ok. I would look at the flap valve and fuel metering and control, sounds like the air measurement or fuel demand to actual supply part throttle is screwed up .
Hope this helps.
PostPosted: Tue Mar 20, 2012 10:03 am    Post subject: Reply with quote
Had this problem after I had done some work on the car.
It was running too lean.
I adjusted the A/F mix a little richer and it now runs fine.
