Second fuel filter?
B
PostPosted: Sat Apr 14, 2012 9:45 am    Post subject: Second fuel filter? Reply with quote
hey everyone,
I was checking a manual today as I was going over some fuel flow issues, and noticed a pre-pump fuel filter. I was not sure what year the manual was from (ebay find) so I was skeptical at first. However when I looked - there is a small canister maybe 1/2 the size of the one in the engine bay. It comes shortly after the line exits the tank and it attaches about 2-3" before the external pump. It is placed as it is shown in the manual.
I noticed someone had posted a note about 2 fuel filters in another post. but no mention of a part number or if replacing it helped. I wondered if anyone else has changed this filter or encountered it at all?
I know that we have to maintain a fairly high fuel pressure and did not want to stick "any old filter" in its place.
Any input would be greatly appreciated
thanks
Sean
("79 924 na)
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Sat Apr 14, 2012 9:09 pm    Post subject: Reply with quote
It's not actually a filter, just a baffle, apparently for sound...
Luvmy80-924
PostPosted: Sun Apr 15, 2012 12:02 am    Post subject: Reply with quote
I agree with 924RACR, it is a baffle not a filter. But if your asking can it be done? I saved my 924 from sitting for almost 8 years from the previous owner. Needless to say the fuel system was a little dirty. A lot dirty really. There was a lot of debris in the tank, I flushed it multiple times but still had a lot of little chunks of rust or something. I was worried about hurting the HP fuel pump so I removed the factory fuel line and installed some new fuel line and a late model GM fuel filter inbetween the tank and the fuel pump. Car still runs great, when the fuel pump starts to whine, I change the filter and it quites back up.
1980 924 N/A Everyday Driver
1986 930
And now a 1980 931
B
PostPosted: Sun Apr 15, 2012 12:17 am    Post subject: Reply with quote
Thanks -
So this should not be a concern for fuel flow
Baffle -? I wonder why they thought a piece like that was necessary there - could it really be that loud?
As for the extra fuel filter that you added luvmy80-924, did you use any specific filter, or just one that had the 90-100(?) pressure capability?
I was kind of thinking about the extra fuel filter as a precautionary measure, but I did not want it to affect the flow from the internal pump to the external pump.
thanks again everyone
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
Luvmy80-924
PostPosted: Sun Apr 15, 2012 7:05 am    Post subject: Reply with quote
The FP can get a little loud, especially when there going bad or starving for fuel. I don't remember what the part number is but it's the same filter my 99 yukon (5.7 SFI) and I screw barbs in the ends. Haven't had a problem yet.
1986 930
And now a 1980 931
924-76
PostPosted: Sun Apr 15, 2012 9:13 am    Post subject: Reply with quote
Is this help?
http://www.924board.org/viewtopic.php?t=26508&highlight=fuel+filter
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
B
PostPosted: Sun Apr 15, 2012 10:37 am    Post subject: Reply with quote
thanks everyone - that is most helpful
I will check with the local Porsche shop to see if that is something they can get
I found a fuel filter a summit racing that will handle up to 100psi and will filter to 5 microns. It is an in-line type and will clamp in place. It is about 2" x 5" - It is $17 - I will have to make sure I have the extra space there to fit it and not bend the hoses too much
It seem like it might be a nice piece of extra security for the external pump.
thanks again everyone for all of the input
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Sun Apr 15, 2012 10:46 pm    Post subject: Reply with quote
on the suction side of the pump there is little pressure.
B
PostPosted: Sun Apr 15, 2012 11:09 pm    Post subject: Reply with quote
thanks Ozzie -
so if I add a filter there I could possibly go with a lower flow rate - maybe one that might be set up for a larger carb something with about 1/2 that flow rate?
thanks
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
!tom
PostPosted: Mon Apr 16, 2012 2:35 am    Post subject: Reply with quote
Not lower flow rate, but less pressure.
You don't want to put a filter before the pump, as this can starve the pump for fuel. The pump needs fuel in it to remain cool and lubricated.
The filter is there to protect the fuel injection system, not the pump. That's not to say that big chunks won't damage the pump.
You should clean the tank with the fuel pump disconnected rather than trying to filter crud out if you suspect the tank has chunks in it. Otherwise, if the tank is in good shape, the fuel filter will filter stuff out prior to the fuel coming back in the tank via the return line.
78 924 NA
5-lug
PostPosted: Mon Apr 16, 2012 8:36 am    Post subject: Reply with quote
Generally all you need is a large mesh filter to prevent larger particles getting to the pump.
Pressure rating doesnt matter.
Large pressure and low micron filters for pre pumps filters are not necessary and can cause fuel starvation problems.
B
PostPosted: Wed Apr 18, 2012 10:42 am    Post subject: Reply with quote
thanks Ozzie
that makes more sense - I was concerned about fuel starvation
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
