sciroccosteve
Joined: 16 Apr 2012 Posts: 215 Location: Rochester, NY
Posted: Tue Apr 17, 2012 12:56 am Post subject: Resolved. |
EDIT:
Issue resolved. Mods can close out if needed _________________ 1979 924
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns
Last edited by sciroccosteve on Wed Apr 18, 2012 9:42 am; edited 1 time in total |
Posted: Tue Apr 17, 2012 2:10 am Post subject: |
Yes. Front and rear alignment are pretty important to how the car feels to the driver. Fix your alignment (a simple string alignment using jackstands and a good measuring tape/angle gauge can get you close enough for most production cars, the rear alignment requires a special tool, but it should be fine if you've not touched it.)
Also, did you look at the strut tops and the steering rack?
How about the the u-joints and tie-rods? They can wear out and cause issues. Tie-rods aren't too bad to source/replace. Steering shaft U-joints are another matter as replacements haven't been sourced from what I can tell.
Ball joints can cause issues as well. Also relatively easily replaced.
How are the rear bearings? Have they been checked for wear and/or repacked recently?
Good luck. _________________ Stefan
sciroccosteve
Posted: Tue Apr 17, 2012 3:43 am Post subject: |
nice!
Rack is great, new inners and outers. new ball joints just installed as well. I have done pretty much everything. I just went out and noticed i didnt properly torque down a sway bar bushing, so that could be a cause.
I feel weird doing the alignment myself, is there a good DIY somewhere on that? It seems to me its easier to spend the 70 bucks at a shop for that one, and get it accurate _________________ 1979 924
2000 V6 Passat
C. Montgomery Burns |
Posted: Tue Apr 17, 2012 10:02 am Post subject: |
Here's a tip: Production car suspension just isn't that accurate, too much deflection is possible thanks to the bushings and their isn't that much to adjust.
http://www.youtube.com/watch?v=sZoL1gaWedA
I do essentially the same process. Although I don't use jack stands to hold the string, I clamp a piece of 1" square steel tube to the front and rear bumpers to take the place of the jack stands.
When using the steel tubing, the string doesn't move in relation to the wheels when I raise and lower the car to make adjustments/bounce the suspension to settle it.
BTW, this is the same process used by many racers I know. Laser racks are faster/easier, but the results are the same. _________________ Stefan
Posted: Tue Apr 17, 2012 11:15 pm Post subject: |
I will be surprised if you can get a shop to do a four wheel alignment for $70. Most of the shops around here won't even touch a car that is older than 20 years. The best success I've had is at a local frame shop. They will do a complete alignment for $200, but I had to bring them the eccentric tool for the rear. In my view, there's no point in doing an alignment if you don't do the rear.
Can you be more specific about what you mean by "variable looseness"? Under what conditions? _________________ erstwhile owner of just about every 924 variant ever made |
Joined: 29 Jul 2001 Posts: 9112 Location: Royal Oak, MI, USA
Posted: Wed Apr 18, 2012 12:14 am Post subject: |
| ideola wrote: | | I will be surprised if you can get a shop to do a good four wheel alignment for $70. |
FTFY... _________________ Vaughan Scott
sciroccosteve
Posted: Wed Apr 18, 2012 12:20 am Post subject: |
| ideola wrote: |
Can you be more specific about what you mean by "variable looseness"? Under what conditions? |
By variable looseness, what I meant was variable due to road conditions. Rockier the road, rockier the car. I was feeling/hearing some noises that sounded to me like loose metal, best way i can describe it would be: Ever hear a loose ball joint? That was the sound.
Since I made this post I have had two findings: I didnt clamp the sway bar tight enough, and number two: The steering column in the cockpit was missing 2 bolts that hold it to the chassis. Since, it has been repaired, now it just feels like im on ice skates with tough turning
Alignments all around! I shall check out that video that has been posted as well. If I can do it myself, I will.
On the 4 wheel alignment note: 70 was the price qouted to me for a 2 wheel, the 4 wheel is 25 more.
I live in a small mountain town, where people don't gouge each other, like in other areas I have lived in. _________________ 1979 924
2000 V6 Passat
