CGT rear fender flare query
PostPosted: Wed May 09, 2012 5:52 am    Post subject: CGT rear fender flare query Reply with quote
I'm finished pulling wire, scraping crap, removing interior stuff in the car. That sucked. Anyway, have a complete '80 931 wiring harness for sale, minus the wires to the rear. The rest of it not cut. Nice shape, even the negative wires attached to the crown posts under the dash were corrosion free. Will post later in for-sale section.
About ready to cut the rear quarter panels to fit the AIR CGT fender flares. However, my set is a used set, with 12 bolts sticking thru the fiberglass inner mounting flare to mount to the car. So, lining the flare up to the body is difficult to figure out how much metal to cut. Anyone have a PDF file with a template for these things?
Also, lining up the flare, front to back, I'm thinking, use the rear bottom inner fender lip, where the stock black plastic thingy used to be? And, the seam underneath the rear quarter to line up the bottom of the flare?
