CIS leaning out in mid rpm range
Goto page 1, 2, 3  Next
daniel
PostPosted: Mon Jun 18, 2012 8:41 pm    Post subject: CIS leaning out in mid rpm range Reply with quote
After recent dyno testing I have noted that the CIS leans out between about 3000rpm to 4000rpm. I have no idea why... I have though of some possible causes/solutions, would like some comments:
1) Possible WUR problem? Now might be the time to convert to one of the electronic versions?
2) Is there some form of electronic controller that can trigger the cold start valve to fix this?
1989 944 Cabriolet
PostPosted: Tue Jun 19, 2012 12:31 am    Post subject: Reply with quote
Vacuum leaks eliminated? System & control pressures within spec? Fuel flow rate within spec?
How lean is it going?
daniel
PostPosted: Tue Jun 19, 2012 11:26 am    Post subject: Reply with quote
Vacume leaks ok,
Fuel pump tank ect is all new so I imagine its ok, plus it come back to way rich at high rpm's
I checked control pressures with the last engine and all were ok.
This thing that bothers me is that the mixture seems to be dependant on revs?
1989 944 Cabriolet
PostPosted: Tue Jun 19, 2012 2:53 pm    Post subject: Reply with quote
daniel wrote:
I imagine its ok
Your imagination is better then mine.
So, how lean at midrange? How rich at high rpm? Gotta graph?
Arvidw
PostPosted: Tue Jun 19, 2012 3:47 pm    Post subject: Reply with quote
Yes, CIS leans out slightly at mid-rpm. (0.5AFR point lower)
Yes, CIS runs ridiculously rich at the redline. (2+AFR point higher)
Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl)
daniel
PostPosted: Tue Jun 19, 2012 4:55 pm    Post subject: Reply with quote
Hi Rasta, I have a graph but I always have a lot of trouble posting pics here. Can I email it to you?
Here is a run down of the figures:
at 2500rpm13.5
sits at 14.8 from3400rpm to 4000rpm than drops to 12.2 at 6000rpm (peak power)
1989 944 Cabriolet
leadfoot
PostPosted: Tue Jun 19, 2012 6:24 pm    Post subject: Reply with quote
could be one or all of your injectors aren't firing properly,
first I would do a quantitive system pressure test... post results
second control pressure cold and warm test... post results
last quantitive injector test of each injector and check spray patterns whilst your at it... post results
the thing about wideband sensor is it just measures fuel from all injectors,
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Min
PostPosted: Tue Jun 19, 2012 11:20 pm    Post subject: Reply with quote
The thing about wideband sensors is they don't measure fuel at all. They measure air. Could be rich misfire. btdt
Min
PostPosted: Wed Jun 20, 2012 1:54 am    Post subject: Reply with quote
My afr is rock steady all way through the rpm range, within afr0,5 if i remember correctly. Can post a plot later. Checked the wur?
leadfoot
PostPosted: Wed Jun 20, 2012 5:26 pm    Post subject: Reply with quote
Min
well actually they don't measure air either because that contains nitrogen and other gases. Oxygen levels in air are about 21% and this is compared to the oxygen level in the exhaust manifold, they sample the oxygen levels outside the exhaust but do not care what the nitrogen is doing.
So realistically, they measure fuel levels just as much as the measure air!!! The point I was making was it factors all injectors and can't differentiate between cyclinders. Also how would a rich misfire cause a lean condition?? you might have to explain that one to me?
Stu
Min
PostPosted: Wed Jun 20, 2012 11:08 pm    Post subject: Reply with quote
Stu
Somehow you've managed to make me lose all desire to share my knowledge. Have a good one.
Min
Arvidw
PostPosted: Thu Jun 21, 2012 7:25 am    Post subject: Reply with quote
Misfire = no combustion
no combustion = no oxygen burned
no oxygen burned = loads of oxygen in exhaust
loads of oxygen in exhaust = lambda sensor reading loads of oxygen (a lambda sensor measures the residual amount of oxygen in the exhaust gasses)
lambda sonde concludes: a lot of air is not used during combustion so there was too much air, too little fuel = lean mixture
Megasquirt thinks: lean mixture, add more fuel !
leadfoot
PostPosted: Thu Jun 21, 2012 10:12 pm    Post subject: Reply with quote
ArvidW, thanks for the clarification, makes sense, misfires though are pretty easy do diagnose so far as the engine generally struggles to get rpm, similar to timing issues... to much fuel... just never really though about it that way.
Min: If only you'd use your powers for good instead of evil...
Stu
PostPosted: Fri Jun 22, 2012 2:46 am    Post subject: Reply with quote
No sheet.
PostPosted: Fri Jun 22, 2012 3:09 am    Post subject: Reply with quote
Rasta Monsta wrote:
No sheet.
I thought Canadians were supposed to be such nice people?
Page 1 of 3
