Cometic head gaskets
Goto page 1, 2, 3, 4, 5, 6  Next
RC
PostPosted: Sat Jul 07, 2012 5:16 pm    Post subject: Cometic head gaskets Reply with quote
Has anyone used one of these Cometic gaskets on a larger than standard bore? Particularly on an 88mm bore?
Has anyone noticed any misalignment?
Has anyone measured the actual bore spacing?
World`s quickest 924 2L slushbox
Allan @ DTA wrote:
I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards
PostPosted: Sun Jul 08, 2012 2:09 am    Post subject: Reply with quote
I am using one on an 87mm bore on the 941. Did not notice an issue, and the car has been running quite strong for several thousand miles.
I would be somewhat surprised if there was a manufacturing/design defect, as we took Cometic a block, an NA head, and a 931 head, which were all scanned and used to create the original part. Of course, anything is possible...
I have 87.5mm and 88.0mm blocks on the bench, both of which I was planning to use with a Cometic gasket. When it cools down later this week, I'll see if I can get out to the garage and check the alignment with one of my unused Cometics.
I presume you are having some sort of alignment issue?
daniel
PostPosted: Sun Jul 08, 2012 10:33 am    Post subject: Reply with quote
88mm bore, cometic gasket from dan, no probs at all
1989 944 Cabriolet
RC
PostPosted: Tue Jul 10, 2012 7:59 am    Post subject: Reply with quote
Sure that you would recall if you noticed part of the head gasket over hanging the bore by 1mm? What about your engine builder?
To be fair though, its less obvious on a smaller bore, wasn`t to me first time round either, neither to a few pro engine builders now also.
No one has measured the gasket bore centres yet?
daniel
PostPosted: Tue Jul 10, 2012 8:48 am    Post subject: Reply with quote
Yes without any question
he is me
I have an 88mm bore
If I had gasket hanging into the combustion chamber, I would have burnt it away and ruined the gasket by now. Had a motor a whil back that had valve relifes cut into the bore, the gasket overhung by less than a mm. The motor didnt even make it to the dyno, the gasket just got destroyed
1989 944 Cabriolet
leadfoot
PostPosted: Tue Jul 10, 2012 4:00 pm    Post subject: Reply with quote
Strange RC, even the stock gasket is still at least 1mm away from a 88mm bore out at 90mm diameter, would have thought it would essentially be the same as there is only one size in stock gasket size.
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
RC
PostPosted: Tue Jul 10, 2012 6:07 pm    Post subject: Reply with quote
The VR and Goetze OE gaskets measure 88.6mm ID uncompressed. They have a bore spacing of 95mm. There is no issue with the stock gaskets.
RC
PostPosted: Thu Jul 12, 2012 3:57 am    Post subject: Reply with quote
Any chance you`ve been in the garage yet or corresponded with Cometic?
PostPosted: Thu Jul 12, 2012 4:28 am    Post subject: Reply with quote
I can't discern a problem on my 88mm block nor with my calipers, but I will send an email to Cometic and ask them to confirm what their drawing shows as the center-to-center distance on the bores.
RC
PostPosted: Thu Jul 12, 2012 5:24 am    Post subject: Reply with quote
Really? Got your glasses on?
What bore spacing do you measure?
PostPosted: Thu Jul 12, 2012 5:50 am    Post subject: Reply with quote
I don't wear glasses, although I am getting older, and perhaps need an eye test.
I did not pre-dispose Cometic to an answer by telling them what we expect the spacing to be. I asked them to refer to the drawing and confirm the center to center spacing. I'll report back when I have an answer.
PostPosted: Thu Jul 12, 2012 6:01 am    Post subject: Reply with quote
my Cometic contact wrote:
Hi Dan,
I also just found out about this, I will be re-cutting the tooling and adjusting all of the parts to the 95mm bore centers next week.
Call and ask for are return goods department to set up any replacements. Tell them I send they are to be replaced no charge.
Thanks
PostPosted: Thu Jul 12, 2012 7:31 am    Post subject: Reply with quote
Ummm...and if the defective gasket was installed and then failed?
PostPosted: Thu Jul 12, 2012 8:12 am    Post subject: Reply with quote
I'm thinking the same thing.
I really don't want to pull the head again....
PostPosted: Thu Jul 12, 2012 12:05 pm    Post subject: Reply with quote
Personally am not worried for anything other than 88mm bores (I have one on the 941 @ 87.5mm bores and have driven many thousands of miles with absolutely no issue so far).
In any event, at present, I don't know what Cometic's approach is going to be for already-installed gaskets. But I when I talk to the returns department (hopefully tomorrow), I will find out.
Page 1 of 6
