'79 924 control pressure to high
Goto page Previous  1, 2, 3
Gene
PostPosted: Sat Sep 08, 2012 2:17 am    Post subject: '79 924 control pressure to high Reply with quote
Have already checked the wru lines for restrictions and also unhooked the return line into a gas can and have good fuel flow there. The wur is rebuilt, had two rebuilds on car infact and another from a good running car and put the one off my car onto the other car and the wru ran that car fine so I'm stumped ! '79 was the only year they had the warm start solinoid but I hot wired it and it seems to work ok. Thinking there might be something in the fuel dist. causing the problem ???
Gene
PostPosted: Sat Sep 08, 2012 2:20 am    Post subject: '79 924 control pressure to high Reply with quote
Should have mentioned that I didn't have the gadge hooked up when I did the test with the wur in the can.
Page 3 of 3
