Manual boost controller, which one to buy?
PostPosted: Tue Sep 18, 2012 9:02 pm    Post subject: Manual boost controller, which one to buy? Reply with quote
There is so many different one with such a large price different that I don’t know which one to choose.
I want:
- in cabin
- set on the fly, no tool required
- ease of use
I don’t want:
- spend more money then needed
- an unreliable pieces of sh!t.
Please share your experience
Thanks
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
kcoyle
PostPosted: Tue Sep 18, 2012 11:20 pm    Post subject: Reply with quote
I am using this one but its under the hood. It's very small and seems well built. I don't goof with it much but its been plug n play. Just turn the knob. Its a tad overpriced IMHO but I found one used on fleabay.
http://www.amazon.com/Turbosmart-TS-0101-1001-Boost-Tee-Boost-Controller/dp/B001N1KV22
and for a real life size scale
PostPosted: Tue Sep 18, 2012 11:32 pm    Post subject: Reply with quote
in cabin boost controllers are generally a bad idea. Too tempting to the driver to turn the wick up.
Also they all work on essentially the same principle (except the electronic version that control a vacuum solenoid) where they control the amount of boost seen by the wastegate using a spring with a small ball as a valve. add more pre-load to the internal spring and the more boost pressure it takes to move the ball off the seat.
Typically the failure mode is that they get dirty internally and the controller is stuck either on full boost. This is true for the high-dollar billet units or the cheap ones built from a Grainger catalog (google Grainger valve).
My suggestion to anyone wanting a boost controller is to place it under the hood and carefully adjust it to the max pressure they want and leave it alone. Also, the wastegate line on the 931 is worth keeping intact as they are getting hard to find, so try to find fittings that will thread in and allow you to make your own line.
Keep an eye on the boost pressure from inside the cabin to ensure it does not exceed the desired limit, pull over and adjust if it does. Make sure to use a locking nut.
If you want selectable boost settings, I suggest moving to an electronic boost controller that uses solenoids. There are several on the market, including DIY solutions, they all work essentially the same and leverage a MAP or pressure sensor to track the pressure in the intake and release the wastegate when the desired target is reached.
PostPosted: Wed Sep 19, 2012 1:01 am    Post subject: Reply with quote
"The writings sp small on it ,cant read it. Does it say do not mount in cabin. If not then 80 bucks is not a bad price. Dan and the RSRguy
both have nice incabin ones... if i went underhood , a boost guage
would make things better.
PostPosted: Wed Sep 19, 2012 1:55 am    Post subject: Reply with quote
I've built them for $10 and they work just as well as the fancy ones. To each their own, I prefer to use solid state controllers to cut down on the work I have to do in the cockpit.
924-76
PostPosted: Wed Sep 19, 2012 8:42 am    Post subject: Reply with quote
kcoyle wrote:
Clean and simple installation, I like it
Thanks
1980 931S
kcoyle
PostPosted: Wed Sep 19, 2012 9:58 am    Post subject: Reply with quote
Also, if you don't want to cut into the WG line, you can buy two hose barbs from the local hardware store and these two specialty adapters (ordered from egauges) to just bolt it in.They are the brass bits in the pic.
Qty Part No Name Price Total
1 R7963 Adapter Bushing - 1/8 NPT female x M14 X 1.5 male $6.40 $6.40
1 R7962 Adapter Bushing - 1/8 NPT female x M12 X 1.5 male $6.40 $6.40
PostPosted: Wed Sep 19, 2012 5:23 pm    Post subject: Reply with quote
i use this the Forge Motorsport T style controller.
i installed it under the hood.
it looks clean to me, i hate all the blue and red sparkling crap you can nowadays buy for your honda....
jazz guy
PostPosted: Thu Sep 20, 2012 1:53 am    Post subject: Reply with quote
fiat22turbo wrote:
in cabin boost controllers are generally a GREAT idea. This ALLOWS the driver to turn the wick up when needed!
Fixed that for you.
All kidding aside, you make a good point. Not having the will-power to resist the temptation could have terrible consequences. That being said...
I've had the boost control knob mounted inside the cockpit for years. I like to run boost just as high as the ambient air temp and gasoline quality allow so I make adjustments almost every time I drive.
DISCLAIMER: YRMV (disastrously!)
edit: btw, I put my controller together using a "Grainger" pressure regulator. Cheap, easy to install, and has worked fine for me for a long time.
Cheers, Brian
PostPosted: Thu Sep 20, 2012 2:31 am    Post subject: Reply with quote
jazz guy wrote:
Fixed that for you.
Cheers, Brian
You know there is a way to have the fuel and boost levels automatically calibrate to ambient temperatures and air pressure, its called "EFI" use it to control boost via solenoid and you can do fun things with the boost levels.
jazz guy
PostPosted: Thu Sep 20, 2012 3:12 am    Post subject: Reply with quote
Well... yeah... if you want to take the "easy" way out. Where's the sport in that?!?
924-76
PostPosted: Tue Nov 13, 2012 6:54 am    Post subject: Reply with quote
Finally got it today, the best one for my GTS poject, a 935/924 GTR boost controller
I bough it as a core, it will need a good clean up and a function test.
I did a blow trough test and play with the adjustment at the same time and so far so good
1980 931S
PostPosted: Tue Nov 13, 2012 7:13 am    Post subject: Reply with quote
Where on earth did you find that? Looks brutal and old, just like it should be! Have been looking for a boost knob that actually fits the 70s turbo look and dont look like a bling bling jap crap thing, and yours is about how it should look Guess there arent more of them were that came from ?
924-76
PostPosted: Tue Nov 13, 2012 7:21 am    Post subject: Reply with quote
In my search I found a clean one for $1000 here (tom1394racing): http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/696065-searching-935-boost-controller.html
Thanks
1980 931S
924-76
PostPosted: Tue Nov 13, 2012 9:08 am    Post subject: Reply with quote
Also, the old style Greddy Trust boost controller is similar looking, easier to find and a lot cheaper.
1980 931S
