Karpaazio
Posted: Mon Nov 19, 2012 10:16 am Post subject: What is this thing and what does it do? with pics |
what is this and what does it do?
Is it possible to eliminate it or will it do something
Thanks, Kalle _________________ Porsche 924 1978 Cabrió:
http://www.garaget.org/?car=219790
Porsche 924 widebody (next up?)
Toyota Crown LS110 1983:
http://www.garaget.org/?car=260537
Audi a6 2.7tt quattro 2000 daily driver |
Posted: Mon Nov 19, 2012 10:34 am Post subject: |
Auxiliary Air Valve.
Adjusts idle based on temperature and time.
You don't want to eliminate it. _________________ Stefan
daniel
Posted: Mon Nov 19, 2012 11:59 am Post subject: |
I have removed mine to no ill affect _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Tue Nov 20, 2012 12:43 am Post subject: |
Generally pretty warm in Syndey, no?  _________________ Vaughan Scott
Bockscar
Joined: 16 Nov 2010 Posts: 392 Location: Sandy, Oregon
Posted: Tue Nov 20, 2012 7:52 am Post subject: |
I've removed the IAC's on older Jettas which perform a similar function as the Aux Air Valve. Generally, they are helpful if you're looking to use the AC because engaging the compressor typically reduces idle speed. I see no reason to remove the aux air valve but if you really want to, crank up the idle a bit before you do. _________________ Brian
'79 924 - Restoration In Progress
'81 924 Turbo w/EFI - Scrapped |
Karpaazio
Posted: Tue Nov 20, 2012 7:57 am Post subject: |
Thanks for your answers guys! Older friend of mine has it removed and seems to work out just fine.. _________________ Porsche 924 1978 Cabrió:
joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
Posted: Tue Nov 20, 2012 8:28 am Post subject: |
I've thought about replacing mine with a solenoid that could be controlled from the cabin.
Also have thought about doing the same with the warm up regulator. Would really need to be in tune with your car to be reliable.  _________________ I got nothin'
Uhhh...you got any pics? |
Bockscar
Posted: Tue Nov 20, 2012 8:34 am Post subject: |
| joejax wrote: | I've thought about replacing mine with a solenoid that could be controlled from the cabin.
Also have thought about doing the same with the warm up regulator. Would really need to be in tune with your car to be reliable.  |
The later model Bosch electronic IAC generally had oily air channeled into them (My old Saab and Jetta was like this) so after many years (like 10 years) of running this way, they would become sticky and would stop working properly. With my Saab, I just cleaned the sucker out real good with a tooth brush and carb cleaner and it worked again. I tried the same method on my Jetta but it didn't fix it so we removed it. We had to bump the idle up just a hair, and the idle ran a bit higher when the car was warmed up.
Regardless, if you're car is a daily driver and you want it to run nice and smooth, I'd just clean it up and leave it. If you're wanting to do something else, remove the thing, clean up the vacuum lines, and bump the idle up. _________________ Brian
Julian
Posted: Fri Dec 07, 2012 1:37 am Post subject: |
| Mine was bad. Caused the idle to function poorly. Sometimes adjusting around it started to cause more issues. Hard to find so I rebuilt mine. Now works well. The timing is right on with the closing. Finding the correct wire to rebuild with is difficult and a little expensive. OHMs are directly related to the wire length. |
