Oil Sending unit
BillA
PostPosted: Mon Mar 04, 2013 12:41 am    Post subject: Oil Sending unit Reply with quote
Does anyone have a good part number for an oil sending unit (81 Turbo) or does anyone have one that they would like to unload?
Thanks
BillA
BillA
1981 931
PostPosted: Mon Mar 04, 2013 2:04 am    Post subject: Reply with quote
The part number is 047 919 561 (same part is used on both the NA and 931).
I do not presently have an inexpensive source for these. They are something like $110 new, and I can only get them direct from Porsche. They used to be available from some of the big catalog / wholesalers, but no more (at least as far as I've been able to determine).
BillA
PostPosted: Mon Mar 04, 2013 4:45 am    Post subject: oil sending unit Reply with quote
I noticed Patrick Motorsports has one listed on EBAY for the 911, 914, but they report that it comes with an adaptor. It looks very much the same as the one for our cars... Guess the 911 & 914 need an adaptor? Wonder if this one will work?
http://www.ebay.com/itm/PORSCHE-911-914-6-OIL-PRESSURE-SENDING-UNIT-CONVERSION-/170283075052?pt=Motors_Car_Truck_Parts_Accessories&hash=item27a5a985ec&vxp=mtr
BillA
1981 931
PostPosted: Mon Mar 04, 2013 5:28 am    Post subject: Reply with quote
It may be just a generic Bosch 0-150 sender.
E-Gauges is a good shop, I bet they can help you.
SlayerSST
PostPosted: Mon Mar 04, 2013 6:46 am    Post subject: Reply with quote
PostPosted: Mon Mar 04, 2013 7:59 am    Post subject: Reply with quote
What Rasta said...
daniel
PostPosted: Mon Mar 04, 2013 8:34 am    Post subject: Reply with quote
VDO p/n 360.032 will work, 10bar, 10-180 ohms and a 12psi switch
and yes I know our gauges are not bar, but the difference is very small
1989 944 Cabriolet
RC
PostPosted: Mon Mar 04, 2013 9:04 pm    Post subject: Reply with quote
As Rasta says, try Egauges.com. Got mine there, about $27 IIRC. Genuine VDO unit without Porsche tax. Its a M10 x 1.0 pitch thread.
World`s quickest 924 2L slushbox
Allan @ DTA wrote:
I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards
PostPosted: Mon Mar 04, 2013 11:07 pm    Post subject: Reply with quote
Can't find the 360-032 part at eGauges, but they appear to have one with the same specs listed above, 360-033:
http://www.egauges.com/vdo_indS.asp?Sender=150PSI_10Bar&PN=360-033
It is $55 + shipping.
This one also appears to be readily available at several of the other large catalog resellers.
PostPosted: Tue Mar 05, 2013 1:21 am    Post subject: Reply with quote
Sure it isn't THIS ONE?
PostPosted: Tue Mar 05, 2013 1:25 am    Post subject: Reply with quote
The difference between those two appears to be in the warning contact, i.e. at what PSI should the warning light be triggered? The -033 model triggers at 29.7psi, and the -023 model at 7psi. So my guess would be the latter.
PostPosted: Wed May 08, 2013 4:14 am    Post subject: Reply with quote
Got my hands on the 360-023 from e-gauges, and discovered a tapered thread. Per VDO tech support, this is all they sell in M10x1.0. They stated if I needed a true straight thread, they could not supply it.
Weighing my options. . .a little uncomfortable attacking my head with a part that should "work," but will alter the OP sender fitting.
Opinions?
joemac
PostPosted: Wed May 08, 2013 12:51 pm    Post subject: Reply with quote
Isn't the original a tapered thread?
Race car: my favourite palindrome.
Porsche: my favourite race car.
PostPosted: Wed May 08, 2013 1:20 pm    Post subject: Reply with quote
should be a 1/8" NPT thread, which is tapered o create the seal.
PostPosted: Wed May 08, 2013 2:14 pm    Post subject: Reply with quote
Original is a straight thread with sealing ring. Runs all the way into my thread checker silky smooth. The one I got from E gauges does not.
