BillA
Joined: 27 Dec 2002 Posts: 170 Location: Syracuse, NY
Posted: Mon Mar 04, 2013 12:41 am Post subject: Oil Sending unit |
Does anyone have a good part number for an oil sending unit (81 Turbo) or does anyone have one that they would like to unload?
Thanks
BillA _________________ BillA
1981 931 |
Posted: Mon Mar 04, 2013 2:04 am Post subject: |
The part number is 047 919 561 (same part is used on both the NA and 931).
I do not presently have an inexpensive source for these. They are something like $110 new, and I can only get them direct from Porsche. They used to be available from some of the big catalog / wholesalers, but no more (at least as far as I've been able to determine). _________________ erstwhile owner of just about every 924 variant ever made |
BillA
Posted: Mon Mar 04, 2013 5:28 am Post subject: |
It may be just a generic Bosch 0-150 sender.
E-Gauges is a good shop, I bet they can help you. _________________ Toofah King Bad
SlayerSST
Posted: Mon Mar 04, 2013 6:46 am Post subject: |
Joined: 29 Jul 2001 Posts: 9122 Location: Royal Oak, MI, USA
Posted: Mon Mar 04, 2013 7:59 am Post subject: |
What Rasta said... _________________ Vaughan Scott
daniel
Posted: Mon Mar 04, 2013 8:34 am Post subject: |
VDO p/n 360.032 will work, 10bar, 10-180 ohms and a 12psi switch
and yes I know our gauges are not bar, but the difference is very small _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
RC
Posted: Mon Mar 04, 2013 9:04 pm Post subject: |
As Rasta says, try Egauges.com. Got mine there, about $27 IIRC. Genuine VDO unit without Porsche tax. Its a M10 x 1.0 pitch thread. _________________ World`s quickest 924 2L slushbox
Posted: Mon Mar 04, 2013 11:07 pm Post subject: |
Can't find the 360-032 part at eGauges, but they appear to have one with the same specs listed above, 360-033:
http://www.egauges.com/vdo_indS.asp?Sender=150PSI_10Bar&PN=360-033
It is $55 + shipping.
This one also appears to be readily available at several of the other large catalog resellers. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Mar 05, 2013 1:21 am Post subject: |
Sure it isn't THIS ONE? _________________ Toofah King Bad
Posted: Tue Mar 05, 2013 1:25 am Post subject: |
The difference between those two appears to be in the warning contact, i.e. at what PSI should the warning light be triggered? The -033 model triggers at 29.7psi, and the -023 model at 7psi. So my guess would be the latter. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed May 08, 2013 4:14 am Post subject: |
Got my hands on the 360-023 from e-gauges, and discovered a tapered thread. Per VDO tech support, this is all they sell in M10x1.0. They stated if I needed a true straight thread, they could not supply it.
Weighing my options. . .a little uncomfortable attacking my head with a part that should "work," but will alter the OP sender fitting.
Opinions? _________________ Toofah King Bad
joemac
Posted: Wed May 08, 2013 12:51 pm Post subject: |
Isn't the original a tapered thread? _________________ Race car: my favourite palindrome.
Porsche: my favourite race car. |
Posted: Wed May 08, 2013 1:20 pm Post subject: |
should be a 1/8" NPT thread, which is tapered o create the seal. _________________ Stefan
Posted: Wed May 08, 2013 2:14 pm Post subject: |
Original is a straight thread with sealing ring. Runs all the way into my thread checker silky smooth. The one I got from E gauges does not. _________________ Toofah King Bad
