electrical problems,..
ThomasJoseph315
Guest
PostPosted: Sun Aug 11, 2013 11:39 pm    Post subject: electrical problems,.. Reply with quote
While I haven't totally dived into this yet into the car, prolly tues. There are a few electrical issues with the turn signals that are not working right. The left rear tail light flashes with the turn signal, not 100% but a little. and the right front turn signal doesn't work at all.
I don't think there is a grounding issue more like a junction or something that needs to be replaced, but is there any spot with these two that would cause issues like this?
There was a bulb in the tail light that wasn't supposed to be there it was like 21W in a 4W socket. I am sure that may have cause some over heating somewhere.
ThomasJoseph315
Guest
PostPosted: Tue Aug 13, 2013 11:57 pm    Post subject: Reply with quote
Ok I think I got this one figured out but I need a simple question answered
The round yellowish side marker lights on the front, are they supposed to blink with the turn signals? I think the car was wired wrong when the front clip was re attached. I see electrical tape all over the place and am thinking someone messed this up. When I disconnect the lights in the front all the ones in the rear work properly, so I know I have an issue with the wiring. I think I have this solved if the side marker lights in the front aren't supposed to blink.
PostPosted: Wed Aug 14, 2013 11:45 am    Post subject: Reply with quote
They do not blink.
ThomasJoseph315
Guest
PostPosted: Thu Aug 15, 2013 2:52 pm    Post subject: Reply with quote
figured as much, thanks! I rewired them correctly yesterday.
