ThomasJoseph315 Guest
Posted: Fri Oct 25, 2013 12:07 am Post subject: What's your gas mileage? |
| I got a 76 with a 4 speed odometer is busted, so I am not sure what I am getting. I think 25-30mpg, what is everyone averaging? |
dubrict
Joined: 22 Apr 2011 Posts: 150 Location: Horseheads NY
Posted: Fri Oct 25, 2013 6:32 am Post subject: |
none of us have any idea, we all have broken odometers _________________ 1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota |
Posted: Fri Oct 25, 2013 6:53 am Post subject: |
I think I got around 8 on the last tank I had on the 924.
Silly ITB's  _________________ Stefan
Posted: Fri Oct 25, 2013 8:29 am Post subject: |
| do they stop at a certain mileage? can I spin the cable backwards? |
Ponz
Posted: Fri Oct 25, 2013 9:09 pm Post subject: |
They are easy to fix. Remove the speedo and carefully remove the trim ring on the face of the speedo. Careful because you will put it back. Remove the back and on the side you will see the split gear. It will most likely not meshing with another gear. You can replace the gear or try to somehow glue it together. The gear is available for about 15 dollars. Yes, it is steep for what you are getting. _________________ 77 1/2 track car
79 931 Euro
87 911 Targa |
hayeslewis
Joined: 21 Aug 2011 Posts: 74 Location: Alexandria, VA
Posted: Sat Oct 26, 2013 5:44 am Post subject: |
6 mpg
 _________________ Hayes Lewis
1979 924 HP
1979 924 ITB/HP???
2007 Armada
2013 Hyundai Elantra
1972 MG Midget Vintage project
Unstable electrified three wheeled Bicycle truck |
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Sat Oct 26, 2013 7:44 am Post subject: |
There seem to clown or two in here. My odometer isn't broken. I get just over 9L/100km, which my converter app tells me is about 26mpg using US gallons (or 31 using proper Imperial ones).
Wade. _________________ '82 British NA - Which I think I've been very lucky with! |
Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Sat Oct 26, 2013 8:02 am Post subject: |
Dont try and glue the broken gear back together because you will just have to go back in and replace it 6000km later, quess how I know.
Its an easy fix. The gear is easy to get to once you open the speedo up.
While you are in there swap the speedo and tach so the tach is in the middle. I was able to do this on two 924's without having to change any wiring. _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting) |
Posted: Sat Oct 26, 2013 3:28 pm Post subject: |
meh,.. nm I'll just leave the odometer alone. I not need to move tach either it's fine where it is.
I really don't even use the MPH on my guage anyway. I use my GPS odometer. I got used to it when I had a truck with over size tires. |
Raize
Posted: Sun Oct 27, 2013 2:06 am Post subject: |
| dubrict wrote: | | none of us have any idea, we all have broken odometers |
This. But back when it worked, my worst MPG between fill-ups was 21MPG, my best was 28MPG, and I normally got 25MPG. |
brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Sun Oct 27, 2013 3:08 am Post subject: |
My odo's busted as well, but I think I calculated that I'm getting about 26 mpg on a good day. _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
Posted: Sun Oct 27, 2013 4:00 am Post subject: |
| Ha,.. here I thought I was the only one with this problem. Bad design flaw I take it from Germany. |
Posted: Sun Oct 27, 2013 4:40 am Post subject: |
| ThomasJoseph315 wrote: | meh,.. nm I'll just leave the odometer alone. I not need to move tach either it's fine where it is.
I moved mine. Took about 5 minutes with the steering wheel off. I like it since you can better see where in the rev range you are when driving spiritedly. The odo/speedo is actually fairly accurate, provided you're running stock diameter tires and the cable is in good shape.
I like having gauges that are easy to scan through when I'm driving, so keeping it simple and homogeneous is preferred, IMO. _________________ Stefan
