Innovative way to cure sunroof leaks....
txjake
PostPosted: Tue Dec 31, 2013 1:08 am    Post subject: Innovative way to cure sunroof leaks.... Reply with quote
Go to post #4. If you don't mind not using it, wrap it.......
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/792618-securing-a-sunroof.html
1978 924, aka The Red Rocker
PostPosted: Tue Dec 31, 2013 1:12 am    Post subject: Reply with quote
I don't understand how that fixes the leak.
PostPosted: Tue Dec 31, 2013 2:04 am    Post subject: Reply with quote
The wraps over sized and covers the seam ... Out of sight out of mind no more leak.
txjake
PostPosted: Tue Dec 31, 2013 2:13 am    Post subject: Reply with quote
This. The wrap covers a great part of the roof. And, can be done in body color. Not a real fix, per se, but a clever band aid.
PostPosted: Tue Dec 31, 2013 2:48 am    Post subject: Reply with quote
From what I saw of that thread, the wrap didn't cover the seam.
txjake
PostPosted: Tue Dec 31, 2013 3:00 am    Post subject: Reply with quote
I see what you are saying, OP's intonation was that it did, after re-looking, it's a bit shy of full coverage. Still, wouldn't be a stretch to do the entire roof with a body colored wrap IF one didn't want to use the sunroof and had bad problems getting a seal.
My leaks are coming from a dealer-installed AC unit and that will soon be fixed. Sunroof doesn't leak per the water test. Just need to get whatever clamps go on the front latch, as they are missing. Uncertain of what they do other than tighten the grip on it, as there is no lifting or air leaks w/o them, at highway speeds.
sbarc
PostPosted: Tue Dec 31, 2013 6:32 am    Post subject: Reply with quote
Duct Tape would seal any sunroof leak for much less.
1981 931 (Canadian car)
1981 931 (US car)
1990 928GT (ROW car)
1991 Toyota MR2
1989 Toyota MR2 Super Charged
1985 Toyota Supra
1973 Triumph GT6
1971 Opel GT
txjake
PostPosted: Tue Dec 31, 2013 6:44 am    Post subject: Reply with quote
yes, and look much worse....
Ian89C4
PostPosted: Wed Jan 01, 2014 2:28 am    Post subject: Reply with quote
Call it racers tape, slap numbers on the side, and all is good
New seals would probably be cheaper than a wrap. I looked into one for the race car and even with just two colors they are not cheap.
The wrap plus install would be about the same as new seals, a couple long necks (or good cigar if you are me) and an hour on a nice afternoon installing them yourself.
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
