1980 924 TURBO
Goto page Previous  1, 2
PostPosted: Wed Dec 18, 2013 8:51 am    Post subject: Reply with quote
Very nice find
Congratulation and welcome aboard
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
walterv
PostPosted: Sun Mar 30, 2014 7:52 am    Post subject: some pictures, new seat, new carpet Reply with quote
I am restoring a 1980 924 Turbo, my wife had one when we were married, promised her I would find one for her again one day.
walterv
PostPosted: Sun Mar 30, 2014 8:03 am    Post subject: Re: 1980 924 TURBO Reply with quote
Walt, welcome to 924board!
walterv wrote:
The rubber spoiler around the rear hatch, shows some pitting on close examination
Very common, not a huge deal, Mother's Back to Black works well on the spoiler.
walterv wrote:
the carpet all needs to be replaced, assume either the hatch leaked, or the sunroof (musty smell)
Check the battery tray very closely. Very important to identify where the water may be coming in. Also, by the fuel filler tube, there is a union there that will sometimes get clogged or disconnect, causing water to seep down into the rear passenger footwell.
walterv wrote:
I have a little problem now with the new used tranny, will post later about that.
Lemme guess, 1st and 2nd are bit crunchy and slow to shift.
walterv wrote:
Motor seems to be fine, little oil leak from what appears to be from a big nut on the oil feed to the turbo by the rack an pinion boot on the passenger side.
Suggest getting a turbo reseal kit, as the crush washers may be leaking oil. Proper torque and periodic retightening is really important to minimize leaks.
walterv wrote:
I do have an idle fluctuation problem, nothing major and again will post about that.
Almost certainly a vacuum leak. Check the flexible rubber boot at the throttle body, and all of the soft rubber elbows and hoses. The elbows in particular are susceptible to cracking, and often cannot be detected until you remove them and inspect the inside corners of the elbows.
Again, welcome to forum, really interested in seeing pix...that two tone green combo is one of my favs.
Ideola,
Thanks for your input and guidance, and yes it is the first to second gig you mentioned, any clue on how to fix that?
Also, figured a vacuum leak, lot's of the stuff (hoses and sort) look original.
Walter
pcelenta
PostPosted: Sun Mar 30, 2014 8:15 am    Post subject: Reply with quote
welcome! another long islander! love the color combo.
check the sun roof drains...behind the rear wheels there is a rubber tube comming out on each side...this is the drain for the sunroof....remove the sunroof and blow compressed air through each side from behind each wheel...you will be amazed how much stuff will blow out. on my old 77.5 most of the remains of the original sunroof seal were in there.
regards,
walterv
PostPosted: Sun Mar 30, 2014 10:06 am    Post subject: Reply with quote
did that prior to replacing the sunroof seal
Thanks
Walter
Page 2 of 2
