2.0l headstuds question
bradelporsche
PostPosted: Fri May 23, 2014 3:26 pm    Post subject: 2.0l headstuds question Reply with quote
Well after finding out I had low compression on cylinders 1 and 2 I decided to take the head off.
This is what I found
Anyone know what brand these are? Also noticed the head centering sleeves are missing. Are these normally left out when head studs are fitted?
I'm thinking about taking these off and going with OEM bolts and find replacement head sleeves? Does anyone have any laying around?
bradelporsche
PostPosted: Fri May 23, 2014 4:00 pm    Post subject: Reply with quote
Also anyone know the torque specs for these?
I made sure they were torqued to 76 but after doing some research they should be torqued down to 90 ft lbs or close to 110nm
PostPosted: Fri May 23, 2014 10:53 pm    Post subject: Reply with quote
If you need the sleeves, I made some once as they are NLA and could walk you thru it. It takes a small drill press, a bunch of bits, some 1/4" pipe and a mini grinder. Plus a bunch of fiddling and fitting.
Mike
PostPosted: Fri May 23, 2014 11:50 pm    Post subject: Reply with quote
Keep the studs. They tend to work better. That said, I'm not sure of the brand except they aren't ARP since those have finer threads and a hex in the top to thread them in more easily. You could notch the tops to make them easier to thread in and out. I suspect the torque specs would be similar to stock but would be more evenly distributed with the studs.
Unfortunately, head gaskets will always fail eventually just due to the different expansion rates of steel and aluminum. Faster if you have a cooling issue of course. Make sure the surfaces are very clean and smooth to help reduce tearing of the gasket over time.
bradelporsche
PostPosted: Sat May 24, 2014 12:29 am    Post subject: Reply with quote
Thanks for the info guys.
I think these may be the raceware head stud version.
The head gasket itself looked fine. The head is suspect. Cyl 1 intake valve guide looks as if it moved down towards the valve.
Dropped of the head at C&M Machine
pmcaya2
PostPosted: Sat May 24, 2014 1:45 pm    Post subject: Reply with quote
Re-torque the head after 1000 miles. My brother-in-law told me to do this and he was absolutely right. I found differences in torque and corrected them. It's fairly easy and good insurance. He said you'd never have the head gasket go bad again .... and so far, he's right again.
I'm curious - did you check the torque before you removed the head? Any evidence of a head gasket leak resulting in low compression? Leak-down test?
pmcaya2
PostPosted: Sat May 24, 2014 2:00 pm    Post subject: Reply with quote
I agree with fiat22 about keeping the studs - you can use a thread gauge to measure the pitch and a die to clean-up the threads, making sure to keep the shavings out of the cylinders.
As far as the head goes, You're right to take it to a good automotive machine shop and have them give it a look. Like surgery, you want someone who does it all the time.
I believe that 90 ft-lbs is correct but I'll check - I think I used the Haynes manual for that info.
peterld
PostPosted: Sat May 24, 2014 2:46 pm    Post subject: Reply with quote
Those headstuds do indeed look like the early version of Raceware headstuds. Later versions had a screwdriver slot in the top, while ARP have hex slots.
Definitely keep the studs as they can be re-used, while headbolts are theoretically one use only.
As you obviously did not fit the studs initially, I would be inclined to pull the studs and run a tap down the holes to ensure correct depth and cleanliness, before reassembling with correct stud lube. While you are at it, run a die over the stud threads.
Unfortunately you will have to make the locating sleeves, but they are not ctitical to reassembly. Though to be sure, to be sure, I prefer them.
80/81 932/8 ROW
jason c
PostPosted: Sat May 24, 2014 3:33 pm    Post subject: Reply with quote
You can remove & install the studs with the double nut method. I would definitely clean them up. I would definitely use the locating sleeves if they'll fit with the studs to minimize head movement. Retorque after 1K miles is required for stretch bolts. The retorque of head bolts is part of the 30k mile service, but I would do it sooner on a car that isn't routinely driven. The headstuds should be reusable and being so, would not be "stretch". It will not hurt to retorque, just don't loosen them.
I would also recommend retorquing head bolts more often on cars that experience extreme ambient temperature changes.
