rlotus
Joined: 30 Apr 2014 Posts: 5 Location: columbus, ohio
Posted: Tue May 06, 2014 4:17 pm Post subject: 16" flat 924t wheels and 15" 944 phone dial wheel |
| Hi guys. Looks like I'm picking up an 82 924t with 16" flat 928 style wheels (don't know what they're called). Much prefer various 944 wheels, like phone dials or even the older 911 spoked wheels. Anybody know if the offsets etc will work? TIA, Ron. |
Posted: Tue May 06, 2014 9:29 pm Post subject: |
Anything with a 52-55mm offset will work on the skinny cars. The stock 'trash cans' with an anodized finish are quite nice. The 928's version are heavier, and have a slightly deeper dish to them. Early 944 'cookie cutters' won't work, they have a 23mm offset. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
kcoyle
Posted: Wed May 07, 2014 6:30 am Post subject: |
What Grenadiers said. 911 "fuchs" are the wrong offset.
Check this thread out.
http://www.924board.org/viewtopic.php?t=21373 _________________ 1982 931- Stock with MBC at 8psi
Posted: Wed May 07, 2014 7:53 am Post subject: |
Fuchs with an ET23 works front and rear for me. Cookie Cutters with an ET23 works for Cedric. Both on 924t's _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
WEASEL149
Joined: 19 Aug 2005 Posts: 595 Location: UK, Sheffield
Posted: Wed May 07, 2014 8:55 am Post subject: |
Yep, Fuchs are well-proven on 924T's.
I must have had mine on for well over 10 years now.
7" rears ET23
6" fronts ET36 _________________ 1979 UK 932 |
Posted: Wed May 07, 2014 3:46 pm Post subject: |
Jupp, works fine, I run wihtouh spacer at the back though. But If i roll the lip it will probably work with spacer.
But this setup can look a bit odd if you have 0 camber up front (why would anyone want that on a sports car?). Then the 6" fronts would probably be a more sensible choice to get the wheels inside the front wings.
Its a little tight up front, but it works
 _________________ 1980 924 Turbo
WEASEL149
Posted: Wed May 07, 2014 5:56 pm Post subject: |
Love that pic Cedric  _________________ 1979 UK 932 |
kcoyle
Posted: Wed May 07, 2014 9:27 pm Post subject: |
I don't understand, I thought they rubbed the fenders. And without the rear spacer do you need special lugnuts to tighten the rims down? _________________ 1982 931- Stock with MBC at 8psi
Posted: Wed May 07, 2014 11:08 pm Post subject: |
| kcoyle wrote: | | I don't understand, I thought they rubbed the fenders. And without the rear spacer do you need special lugnuts to tighten the rims down? |
I threw the alu nuts away the first thing I did since I do a lot of track driving and need robust stuff, lots of Wheel changing per season. So I have the open ended steel nuts.
you need a long socket to tighten the nuts, they stick out a bit, you swear a lot when you forget to take it with you to the track and you are 3h away from home  _________________ 1980 924 Turbo
kcoyle
Posted: Thu May 08, 2014 4:27 am Post subject: |
My bad then, they do fit. Would the below rims be a direct bolt on for a street car with factory suspension?
7x16 ET23 rear
6x16 ET36 front _________________ 1982 931- Stock with MBC at 8psi
Janne J
Posted: Sat Jun 07, 2014 8:01 pm Post subject: |
I have 7*15 Fuchs ET23 with Yokohama 205/50 all round on my 924S-88.
2 degrees negative camber and the front wheels clears the fender.
 _________________ Porsche 924S 1988, Porsche 911SC 1982 Porsche 944S2 1990 |
Posted: Sun Jun 08, 2014 2:57 am Post subject: |
Proof above that they "fit," but they certainly aren't ideal. Don't get me wrong, I love the look and understand why people install them, but they are not the correct offset. With late offset wheels, you can get an extra inch per corner of rubber under the car, yes? _________________ Toofah King Bad
Janne J
Posted: Sun Jun 08, 2014 4:32 am Post subject: |
Fuchs wheels is for trackday use. They are lighter, smaller diameter gives better acceleration, and wider track enhanches grip.
My roadwheels is the frontwheels from a 996, 7*17 Et55 with Bridgestone RE002 205/50*17.
