Posted: Wed Jun 25, 2014 7:23 am Post subject: Interpret my head gasket |
Getting started on resealing the '88 924S engine for the track car. Pulled the head today, and am quite concerned about the condition of the original head gasket. Compared to the 2.0L engine, the water jackets are quite large. And, from the photos, you'll see that some of the gasket is missing. I noticed a buildup of something at the thermostat, and think it could be part of the missing head gasket material. The cylinder bores are perfect, some oil in the oil cooler, have a pic of that. Is this OEM head gasket condition sorta normal? About 95,000 miles on the engine.
From the top:
Block side:
oil cooler:
some of the missing material fell off as I removed HG.
 _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Wed Jun 25, 2014 11:48 am Post subject: |
Gasket looks ok, but that looks like oil + coolant milkshake. Did you find anymore of this in the coolant tank or oil pan? _________________ White 87 924S "Ghost"
Posted: Wed Jun 25, 2014 10:32 pm Post subject: |
no, the coolant came out clear, and no milkshake oil in the pan. Pulled the number two rod bearing, and it looks perfect.
Bores are smooth, no scratches.
Posted: Sat Jun 28, 2014 12:33 pm Post subject: |
Then that gunk is probably due to poor maintenance of the cooling system. _________________ White 87 924S "Ghost"
