JEREMY74
Posted: Fri Jun 27, 2014 11:24 am Post subject: radiator fan please help |
when i drove into the garage and parked the other day i noticed the radiator fan was still running. it was pretty hot outside and i know this is normal to run after you turn the car off to cool the motor down. i went inside the house for 60 minutes or so and came back out and it was still on. i disconnected the negative battery cable so it wouldnt drain my battery. the battery has full charge now. if i hook up the negative cable back to the battery the fan starts back up. do you think this could be a stuck temperature thermostat relay? i cant figure out witch relay this would be. i know where they are located. any help is greatly appreciated since this is my daily ride to work. just turned over 100k on the milage. thanks. _________________ 1987 PORSCHE 924S |
edredas
Posted: Sat Jun 28, 2014 4:27 am Post subject: |
Try pulling one of the wires off the the thermo temp switch on the radiator. If the fan turns off, then the switch is bad.
Here is a more in depth troubleshooting guide for the cooling fans.
http://www.clarks-garage.com/pdf-manual/cool-01.pdf _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
Posted: Sat Jun 28, 2014 5:44 am Post subject: |
if fan is running full tilt with key off "ac relay" is bad _________________ Toofah King Bad
JEREMY74
Posted: Sat Jun 28, 2014 7:57 am Post subject: |
i pulled both wires off of the thermo temp switch on the radiator and the fan still runs. i also took out the ac relay and the fan still runs. _________________ 1987 PORSCHE 924S |
JEREMY74
Posted: Sat Jun 28, 2014 8:01 am Post subject: |
only the passenger side fan runs _________________ 1987 PORSCHE 924S |
JEREMY74
Posted: Sat Jun 28, 2014 11:37 am Post subject: |
i took out the cooling fan relay the first relay on the top left side and the fan stopped. the relay must be stuck on. ive got a new one on the way and will post if this does the trick. thanks you guys for the assistance and direction. _________________ 1987 PORSCHE 924S |
Posted: Sat Jun 28, 2014 12:16 pm Post subject: |
Check the wires that go to the fan switch for shorts to ground. Only one should be 0 ohms to ground. If both are grounded, fans will run. Sometimes the spade connectors' insulation at the fan switch is damaged and causes a short to ground. Sometimes the insulation on the wiring is damaged. _________________ White 87 924S "Ghost"
JEREMY74
Posted: Tue Jul 01, 2014 10:17 am Post subject: |
ok. ill check that also. thank you paul. i was waiting on the new relay to arrive. ill let you know what i find. _________________ 1987 PORSCHE 924S |
JEREMY74
Posted: Sun Jul 06, 2014 10:55 am Post subject: |
it was the relay. i put the new one in and its running fine now. thanks for the input guys.  _________________ 1987 PORSCHE 924S |
