Torque spec question
jazz guy
PostPosted: Sun Jul 27, 2014 2:53 pm    Post subject: Torque spec question Reply with quote
I'm working on putting the rear suspension back in my 82 931 and it's come time to torque the bolt that attaches the trailing arm to the torsion tube. I checked the Haynes and it says 177 foot/pounds. That sounds really high and I don't trust it. I did a little interwebs searching and didn't find anything definitive on the 924 but found several listings for the 944 that spec'd 46 ft/lbs. Anyone know the correct spec?
'81/'81/'82
PostPosted: Sun Jul 27, 2014 9:23 pm    Post subject: Reply with quote
Which one, exactly? There are many...
kcoyle
PostPosted: Mon Jul 28, 2014 1:24 am    Post subject: Reply with quote
I'm puzzling over some torque specs myself so I have the FSM open alrready. This page is from my 931 PDF FSM.
jazz guy
PostPosted: Mon Jul 28, 2014 1:40 am    Post subject: Reply with quote
This one:
That is exactly what I needed! Looks like it is the trailing arm to torsion bar tube = 44 ft lbs
Cheers! Brian
'81/'81/'82
PostPosted: Mon Jul 28, 2014 1:51 am    Post subject: Reply with quote
Agreed; you were obviously being pointed at the M16 bolts that also form the height adjustment, with the eccentric.
Usually bolt size is a general guideline in itself to an appropriate torque, beyond that come the specifics of fitment and usage (with respect to our cars - grade doesn't vary much on the cars)...
