jazz guy
Posted: Sun Jul 27, 2014 2:53 pm Post subject: Torque spec question |
I'm working on putting the rear suspension back in my 82 931 and it's come time to torque the bolt that attaches the trailing arm to the torsion tube. I checked the Haynes and it says 177 foot/pounds. That sounds really high and I don't trust it. I did a little interwebs searching and didn't find anything definitive on the 924 but found several listings for the 944 that spec'd 46 ft/lbs. Anyone know the correct spec? _________________ '81/'81/'82 |
Joined: 29 Jul 2001 Posts: 9138 Location: Royal Oak, MI, USA
Posted: Sun Jul 27, 2014 9:23 pm Post subject: |
Which one, exactly? There are many... _________________ Vaughan Scott
kcoyle
Posted: Mon Jul 28, 2014 1:24 am Post subject: |
I'm puzzling over some torque specs myself so I have the FSM open alrready. This page is from my 931 PDF FSM.
 _________________ 1982 931- Stock with MBC at 8psi
jazz guy
Posted: Mon Jul 28, 2014 1:40 am Post subject: |
| 924RACR wrote: | | Which one, exactly? There are many... |
This one:
| kcoyle wrote: | | This page is from my 931 PDF FSM. |
That is exactly what I needed! Looks like it is the trailing arm to torsion bar tube = 44 ft lbs
Cheers! Brian _________________ '81/'81/'82 |
Posted: Mon Jul 28, 2014 1:51 am Post subject: |
Agreed; you were obviously being pointed at the M16 bolts that also form the height adjustment, with the eccentric.
Usually bolt size is a general guideline in itself to an appropriate torque, beyond that come the specifics of fitment and usage (with respect to our cars - grade doesn't vary much on the cars)... _________________ Vaughan Scott
